- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I recently bought a system with MSI MAG B860 Tomahawk Wifi mother board (Link). It has Killer LAN and WiFi/BT. I have downloaded latest available Killer Performance Suite from the Intel website but when I try to install it in Windows Server 2025 LTSC, the installation aborted with the message that the OS is not supported. Is there any way I can download/install the network drivers in Windows Server 2025 LTSC?
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello rhinjard,
Thank you for reaching out to Intel® Customer Support and for posting your query on the Intel Community regarding Intel® Killer™ driver support for Windows Server 2025. We truly appreciate your engagement, and we are happy to assist you with this.
We understand that you are looking into driver compatibility and support options for your Intel® Killer™ adapter on Windows Server 2025, and we want to make sure we provide you with the most accurate and relevant assistance possible.
To better investigate your query and provide you with a precise resolution, we kindly request you to share the following information:
Intel® Killer™ Adapter Model – Could you please let us know which Intel® Killer™ network adapter is currently installed on your system? (e.g., Killer™ E3100, Killer™ Wi-Fi 6E AX1675, etc.)
Windows Server 2025-Specific Driver Availability – Have you already explored or attempted to download drivers that are specifically designed and listed for Windows Server 2025?
Intel® System Support Utility (SSU) Log – To help us better understand your system configuration, please run the Intel® SSU tool and share the generated log file with us. You can download and find instructions for the tool at the following link: Intel® System Support Utility (SSU)
Please Note: Before generating the SSU report, kindly ensure that the "Networking" option is unchecked prior to running the scan.
Additionally, we would like to bring the following important information to your attention:
Please Note: The Intel® Killer™ Performance Suite currently supports only Windows 10 and Windows 11 (64-bit) operating systems. Windows Server 2025 is not an officially supported operating system for the Intel® Killer™ Performance Suite at this time. We understand this may not be the answer you were hoping for, and we sincerely appreciate your patience and understanding.
Once we receive the above details, we will be in a much better position to investigate and guide you toward the right solution.
To download the compatible network drivers supported by your operating system, we recommend that you visit the following download page Intel® Network Adapter Driver for Windows Server 2025*
Please do not hesitate to reach out if you have any questions in the meantime. We look forward to hearing from you and are committed to getting this resolved for you.
Thank you for your support and time.
Tharun
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello rhinjard,
Hope you're doing well!
This is a gentle follow-up on our previous email regarding your Intel® Killer™ driver compatibility query for Windows Server 2025. We noticed we haven't heard back from you yet and wanted to check in to see if you've had a chance to review the details we shared.
To recap, we kindly request your assistance with the following so we can move forward with the most accurate resolution:
Intel® Killer™ Adapter Model — Please let us know which Intel® Killer™ network adapter is installed on your system (e.g., Killer™ E3100, Killer™ Wi-Fi 6E AX1675, etc.)
Windows Server 2025-Specific Driver Availability — Have you already explored or attempted to download drivers specifically listed for Windows Server 2025?
Intel® SSU Log — Please run the Intel® System Support Utility (SSU) and share the generated log with us. Instructions can be found here: https://www.intel.com/content/www/us/en/support/articles/000057926/memory-and-storage.html. (Kindly ensure the "Networking" option is unchecked before running the scan.)
As also mentioned in our previous email, please note that the Intel® Killer™ Performance Suite currently supports Windows 10 and Windows 11 (64-bit) only, and Windows Server 2025 is not an officially supported operating system at this time. In the meantime, you may also explore compatible network drivers for your operating system via the https://www.intel.com/content/www/us/en/download/838943/intel-network-adapter-driver-for-windows-server-2025.html download page.
Your response will allow us to move forward promptly and ensure you receive the right guidance without any further delays.
We appreciate your time and patience, and we look forward to hearing from you soon!
Tharun
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello rhinjard,
Thank you for reaching out to us and for your patience throughout this process.
As we have not received a response from you following our previous correspondence, we will now be closing this support thread. Please note that this thread will no longer be actively monitored going forward.
Should you have any further questions or require additional assistance, we kindly ask that you initiate a new support thread, and our team will be happy to help.
Thank you again for giving us the opportunity to assist you.
Tharun
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
