Wireless
8900 Discussions
Intel(R) Wi-Fi 6 AX201 160MHz PEAP certificate authentication failure under Windows 11
Eldertoon
This issue is strange. We received a new batch of Laptop and decided to provision using Windows 11. Those are Lenovo E15gen2, X13 and P17. All share the same Intel WiFi chipset and recent drivers. All failed to use the WiFi using computer certificates, using PSK WiFi is no issue. Note that we also have other laptops using the same provisioning template but with other Intel chipsets or Realtek one and the issue does not occur.
I decided to test multiple version of the drivers and all failed. Attached is the SSU using latest found.
22.0.1.5 17/1/2021
22.150
22.180
22.200.2.1 9/3/2023
So, I decided to move to Windows 10 and give it a try: the problem is not reproduced. Attached is the SSU using latest driver on the same hardware.
Failure of connecting is that a logi/password is requested when connecting to the WiFi. This means that the certificate was not found, not valid or not accepted. On the AP controler, no tries are received with a certificate. I can use MMC.EXE and computer certificate snap in to confirm the certificate is there and valid. Renewing it (by deletion or by requesting a new one) doesn't solve the issue.
I also attached the exported XML from netsh wlan. When I import it on the failing computer, the login/password is not requested, it is an immediate failure (can't connect you to the network). Nothing is logged in event viewer.
I could have logged an error to Microsoft support, but since different hardware and different software solve the issue, it is related to the driver for me. But I have no clue how to get a verbose log from it.
Alberto_R_Intel
Eldertoon, Thank you for posting in the Intel® Communities Support.
We are sorry to hear about this issue and we will be more than glad to assist you with this matter.
In order to try to find a possible solution to this topic, we will do further research on this matter. As soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello Eldertoon, I just received an update on this matter.
While we are still working on this scenario, we just wanted to confirm if you have the option to test any of the systems on a different network? Once you get the chance, please let us know the results.
Albert R.
Eldertoon
I confirm connecting to a standard WPA2/PSK network is not an issue. My issue is only with WPA2/computer certificate network.
Jean_Intel
Hello Eldertoon
It is important to mention that certificates are managed by the Operating System not by our drivers. Since the issue is only present in Windows* 11 and not in Windows* 10, if the issue still persists, then we would recommend as the next thing to do, to get in contact directly with the manufacturer of the computer for further assistance on this matter.
https://support.lenovo.com/us/en
Jean O.
