Wireless
9033 Discussions
Intel(R) Wireless-AC 9560 160MHz
Jason70
After the latest windows 11 update I can no longer use the 5G network in my home network. The 2.4GHz network works but when I switch to the 5G network it no longer works.
When connected to the 5GHz network there is no network connectivity, no Google or webpages etc
Is this a known issue and is there something I can do to fix it?
DeancR_Intel
Hi Jason70,
Thank you for posting in the Community!
Please share some details more about the issue:
What is the symptom of the issue?
Have tried a roll back to a previous driver version for testing?
Is this a laptop or a desktop?
Is this issue happening at home, office environment or both?
Have you checked if this issue happens on different networks?
Dean R.
DeancR_Intel
Hi Jason70,
Dean R.
DeancR_Intel
Hi Jason70,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
cre_rafael
O adaptador de rede simplesmente parou de funcionar e apresenta o erro (O Windows interrompeu este dispositivo porque encontrou problemas. (Código 43), já atualizei para o drive mais recente da Intel e até mesmo voltei para o driver antigo, reinstalei o sistema operacional por completo e mesmo assim não funcionou, não sei mais o que fazer para que o mesmo volte a operar.
Versão do driver: 23.120.0.3 / Data: 06/02/2025
DETALHES DO ERRO
O dispositivo PCI\VEN_8086&DEV_51F0&SUBSYS_00348086&REV_01\3&11583659&0&A3 teve um problema ao iniciar.
Nome do Driver: oem80.inf
Guid da Classe: {4d36e972-e325-11ce-bfc1-08002be10318}
Serviço: Netwtw10
Filtros Inferiores:
Filtros Superiores: vwifibus
Problema: 0xA
Status do Problema: 0xC0000001
SAMSUNG GALAXY BOOK 2 - I5 / Iris XE (2024)
Agradeço se alguém puder me ajudar
