Wireless
8599 Discussions
Intel® Wi-Fi 6 AX201 lastest driver version not working
userwithdrivererror
I am experiencing persistent driver-related issues with my Intel® Wi-Fi 6 AX201 160 MHz adapter on Windows 10/11. The Event Viewer logs show repeated internal driver errors and watchdog resets. These problems began after updating to recent driver versions (22.2xx series). Rolling back to an older driver temporarily resolves the issue.
Observed Event Viewer Errors:
  • 7017 – Secure Boot (SB) configuration
  • Intel(R) Wi-Fi 6 AX201 160MHz: The network adapter is not functioning properly.
  • Internal error.
  • 5032 – Driver Miniport reset watchdog
  • The adapter returned an invalid value to the driver.
  • Fatal error: The miniport has detected an internal error.
  • The driver entered RTD3. All connected devices will be removed from the driver’s internal state, DeviceDisconnected events are expected.
Troubleshooting steps taken:
  • Clean driver reinstall (uninstall device, remove driver software, reboot, install latest Intel driver).
  • Tested multiple driver versions — recent 22.2xx releases cause instability, older versions such as 22.170.0.3 and 22.160.0.4 are more stable.
  • Disabled 802.11ax mode and reduced transmit power — partial improvement, but not a complete fix.
  • Disabled “Allow the computer to turn off this device to save power” and set Wireless Adapter settings to Maximum Performance.
Request:
  • Confirmation if this is a known regression in the recent AX201 driver versions.
  • Recommendations on a stable driver version officially supported for AX201.
  • Any official fix or updated driver addressing RTD3 handling and watchdog resets.
System details:
  • Intel® Wi-Fi 6 AX201 160 MHz
  • Windows 11 (latest updates)
  • Secure Boot enabled
  • Problem reproducible after wake from sleep/Modern Standby and under high network load.
Mike_Intel
Hello userwithdrivererror,
  1. What is the brand and model of your system?
  2. Can you tell me where did you downloaded the driver?
  3. How did you update the driver?
  4. For me to review the hardware and installed drivers, kindly help generate the SSU logs of your system. Please refer to the link below on how to generate the logs:
Michael L.
userwithdrivererror
Thank you for your reply. Please find the requested details below:
  • System brand and model: ASUSTeK COMPUTER INC. ASUS TUF Gaming F15 FX506HC_TUF506HC
  • Driver download source: Intel® Download Center
  • Driver update method: Manual installation via downloaded installer from Intel® Download Center.
  • SSU Logs: Please find attached the generated SSU logs as requested.
Additional notes:
  • The issue persists across multiple clean driver installations.
  • Only older driver versions seem stable.
  • The problem reappears immediately after updating to latest versions donwloading from Intel® Download Center and through Windows Update.
  • Problems occur both after wake from sleep/Modern Standby and under high network load.
Let me know if you require any additional details or specific test cases.
Mike_Intel
Thank you for the update.
Based on your reply, it seems that you are having issues with Intel Generic driver.
Can you try the OEM's latest driver? This driver is from your laptop manufacturer and this driver should work on your system.
Here is the download link:
2021 ASUS TUF Gaming F15|Laptops For Gaming|ASUS Philippines
Michael L.
userwithdrivererror
Hi Michael,
Thank you for your response and for suggesting the use of the ASUS OEM driver. I have installed the latest version provided by ASUS (23.130.1.1), but the WiFi connectivity issue persists, just as it did with the Intel generic driver (23.150.0).
Since neither the OEM nor the generic driver resolves the issue, I understand this might be a compatibility problem with my model or with the latest Windows update. I have noticed that the Event Viewer shows multiples errors related with the Netwtw10 service, although this issue may be caused by various factors.
I appreciate your assistance and consider this case closed on my side.
Thank you for your support.
userwithdrivererror
Dbxian
I’m also using the Intel(R) Wi-Fi 6 AX201 160MHz and having the same issues. Especially within the past month, I’ve noticed a lot of people reporting this around the same time, so I don’t think it’s just a simple hardware failure.
In my case, when I switch to a USB Wi-Fi adapter everything works perfectly, which shows that my network and system are fine. This makes me believe the problem is more related to the AX201 driver (or its compatibility with recent Windows updates) rather than the card itself being defective.
Still no fix or reliable solution so far, and having to rely on a USB Wi-Fi adapter that’s much slower compared to the built-in AX201 is really frustrating.
Mike_Intel
Before closing this ticket, let me just add or explain the difference between generic driver and OEM driver.
Generic driver is from Intel or manufacturer of the card that should work for all the cards out there, however OEM manufacturers can alter or modify the cards based on the design of the system and it is being controlled by their BIOS. So technically speaking, it is recommended to use OEM driver to enable the modifications made.
In this case, since you already tried both drivers, you may try to contact Asus to further check the configuration and also diagnose if this is a hardware issue.
Michael L.
Dbxian
Mike_Intel
@Dbxian
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Mike_Intel
I am sending another follow up and hoping that you are now also talking to the OEM manufacturer for further assistance.
Michael L.
userwithdrivererror
Hi
I'm taking OEM manufacturer assistance.
