- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have the Intel Wi-Fi 7 BE201 Wireless card (without vPro) (https://www.intel.com/content/www/us/en/products/sku/230079/intel-wifi-7-be201/ordering.html) and I am trying to get it to work in Ubuntu Linux 24.04 LTS.
Here some diagnostics:
sudo dmesg | grep iwlwifi
[ 2.960426] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x80400 wfpm id 0x80000020
[ 2.960463] iwlwifi 0000:00:14.3: PCI dev 54f0/00e4, rev=0x370, rfid=0x20112200
[ 2.960467] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[ 2.960627] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-so-a0-fm-c0-89.ucode failed with error -2
[ 2.960635] iwlwifi 0000:00:14.3: no suitable firmware found!
[ 2.960639] iwlwifi 0000:00:14.3: iwlwifi-so-a0-fm-c0-89 is required
[ 2.960641] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
sudo lsmod | grep iwlwifi
iwlwifi 647168 0
cfg80211 1474560 4 rtlwifi,iwlwifi,mac80211,rtl8xxxu
ls -l /lib/firmware/iwlwifi-bz*
-rw-r--r-- 1 root root 624834 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-fm-c0-92.ucode.zst
-rw-r--r-- 1 root root 630666 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-fm-c0-94.ucode.zst
-rw-r--r-- 1 root root 633296 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-fm-c0-96.ucode.zst
-rw-r--r-- 1 root root 47973 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-fm-c0.pnvm.zst
-rw-r--r-- 1 root root 1836712 Okt 24 15:30 /lib/firmware/iwlwifi-bz-b0-gf-a0-100.ucode
-rw-r--r-- 1 root root 566927 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-gf-a0-92.ucode.zst
-rw-r--r-- 1 root root 570276 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-gf-a0-94.ucode.zst
-rw-r--r-- 1 root root 573360 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-gf-a0-96.ucode.zst
-rw-r--r-- 1 root root 1777464 Okt 24 15:28 /lib/firmware/iwlwifi-bz-b0-gf-a0-99.ucode
-rw-r--r-- 1 root root 55208 Okt 24 15:28 /lib/firmware/iwlwifi-bz-b0-gf-a0.pnvm
-rw-r--r-- 1 root root 7586 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-gf-a0.pnvm.zst
-rw-r--r-- 1 root root 508893 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-hr-b0-96.ucode.zst
-rw-r--r-- 1 root root 330 Sep 18 15:29 /lib/firmware/iwlwifi-bz-b0-hr-b0.pnvm.zst
I need the firmware file iwlwifi-so-a0-fm-c0-89.ucode as stated by the iflwifi output.
I have checked https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/intel/iwlwifi but the needed file is not available.
Can you please check for availability of this file?
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello nilsbyte,
1) Is this a newly purchased device with out-of-the-box issue?
2) Is the Intel® Wi-Fi 7 BE201 a pre-installed component on your device or is this a replacement or upgrade component on your system?
3) Please help share your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for the Linux* Operating System.
- Download the Intel® System Support Utility for the Linux* operating system and save the ssu.tar.gz file to your system.
- Extract the ssu.sh file from ssu.tar.gz and save to your system.
- To run the ssu.sh script from a Linux* terminal, Open Applications->Accessories->Terminal.
- From the current directory, navigate to the current folder where the ssu.sh file resides. For example, if you saved the ssu.sh file to a folder called SSU File, the command would be cd SSU File.
- Run the ssu.sh file using this command: ./ssu.sh <parameter=0|1> where 0 = off and 1 = enabled.
- Use the parameter definitions included in the readme to determine which parameter to use.
Note:
- If no parameter is specified and only ./ssu.sh is run, it captures all system information with the exception of 3rd party logs that must be specified.
JeanetteC.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Jeanette,
1. It's a newly purchased Wifi 7 BE201 module
2. I have installed the module in an existing system. The module is successfully recognized but the operating system (Ubuntu 24.04 LTS) is missing the firmware file (iwlwifi-so-a0-fm-c0-89).
3. I currently can not access the device and cannot provide the details from ssu
As stated before, the Linux Kernel Repository is missing the firmware file needed by iwlwifi. I am using Linux Kernel 6.17.5
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello nilsbyte,
Thank you for the information about your newly purchased WiFi 7 BE201 module.
I understand that while the module is recognized in Ubuntu 24.04 LTS with Linux Kernel 6.17.5, you're missing the required firmware file (iwlwifi-so-a0-fm-c0-89) from the Linux Kernel Repository.
Let me check on this internally for now and I will post an update once it is available.
Best regards
JeanetteC.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Yes, this is correct @JeanetteC_Intel . Please check with your driver engineering team.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello nilsbyte,
Please note that I am continuing to work on resolving this issue. I have sent you a private email regarding important details that require confidential discussion. Please check your inbox, spam, and junk folders to ensure you receive the message.
JeanetteC.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello nilsbyte,
Please continue to install the latest (and stable) version of the mainline kernel, 6.17, from kernel.org, which includes the latest wireless drivers, and install the latest wireless firmware from firmware git tree for the Intel BE201, version only
iwlwifi-bz-b0-fm-c0-100 and iwlwifi-bz-b0-fm-c0.pnvm
This should help resolve the issue you're experiencing.
JeanetteC.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello Jeanette,
Please read my previous posts in this thread.
- I already said that I have installed 6.17.5 kernel on my system. you even confirmed my statement.
- The iwlwifi driver demands the firmware file "iwlwifi-so-a0-fm-c0-89" on my system. You confirmed that you understood that, too.
Why are you now repeating to suggest installation of kernel 6.17 if i have already done so before posting this thread?
Why are you suggesting iwlwifi-bz-b0-fm-c0-100 and iwlwifi-bz-b0-fm-c0.pnvm? These are not the files iwlwifi is demanding.
Please escalate this case to your driver engineering team.
Thank you
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello nilsbyte,
You're absolutely right, and I apologize for the confusion. I'll investigate this internally and provide an update as soon as it's available.
JeanetteC.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello nilsbyte,
We have identified the issue with the following information below.
Root Cause:
- Your Linux distribution is pointing to an incorrect firmware path.
Recommended Solution:
1) Download the correct firmware files from: https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/intel/iwlwifi
2) Install manually using these commands:
# sudo cp iwlwifi-* /lib/firmware/'
# sudo modprobe iwlwifi
Alternative:
- Contact your Linux distribution support to update the firmware path configuration.
This should resolve the connectivity issues you've been experiencing. Please let me know if you need any clarification on these steps or encounter any difficulties during the process.
JeanetteC.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello nilsbyte,
Have you had a chance to look over the previous post?
If you have any questions, please don't hesitate to reach out.
JeanetteC.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have the exact same issue - is there any update to this? I tried downloading the files specified in the link above, but it is missing 2 of the files (99 and 102), and when I try to reload iwlwifi I get the following errors:
uCode file size 14829154 does not match expected size
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hello HegeE,
Thank you for sharing your experience! I understand you're encountering the same iwlwifi uCode size mismatch issue, specifically with missing files 99 and 102, and the error about file size 14829154 not matching the expected size.
While your issue appears similar to the original post, the specific details (missing files and exact error codes) suggest there may be unique aspects to your situation that require focused troubleshooting.
I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Sincerely,
JeanetteC.
