Wireless
8846 Discussions
Intel WiFi 6 AX201 160MHz (rev 01) does't work at all (Linux)
mirkojoshua
HI,
my mini PC running Ubuntu 22.04 (kernel 5.19.0-35-generic) with an Intel Corporation Wi-Fi 6 AX201 160MHz (rev 01). Unfortunately this WiFi module doesn't work at all. I can't search the connection and also the WiFi menu is missing from the OS settings.
Bluetooth doesn't work either, but I don't know if the problem is related
I have inserted some attachments with the output of debug commands.
Jean_Intel
Hello mirkojoshua,
Thanks for waiting for a response.
This time, we would like to recommend your installing the latest stable kernel version available for your operating system.
Jean O.
Jean_Intel
Hello mirkojoshua,
Thank you for posting on the Intel️® communities. We understand that you are unable to properly use the Intel WiFi 6 AX201 160MHz on Ubuntu 22.04.
  • Did the wireless card work as expected on other Operating Systems?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
Also, please provide me with the output for the following reports:
  • To check whether the Wireless adapter is connected correctly: # lspci​
  • To check whether this is an iwlwifi issue: # modinfo iwlwifi​
    • In case the result there is no output  type: # lsmod | grep iwlwifi​
  • To check whether the suitable firmware is installed: # dmesg | grep “no suitable firmware found!”​
Jean O.
mirkojoshua
Hi Jean,
Wireless card work on Windows and the adapter is pre-installed with my system.
Have you seen the two files attached to my first post? They contains all requested report
Jean_Intel
Hello mirkojoshua,
We will do further research on this matter and post the response on this thread once available.
Jean O.
Jean_Intel
Hello mirkojoshua,
Jean O.
mirkojoshua
Jean_Intel
Hello mirkojoshua,
Thanks for letting us know that you will try the latest kernel version. We will keep this thread open for a bit to see if the issue is still present after updating the kernel.
Let us know if you face any inconvenience.
Jean O.
Jean_Intel
Hello mirkojoshua,
We hope you are doing fine.
Best regards.
Jean O.
