Wireless
9023 Discussions
Intel WiFi Driver Installer Deleted Graphics/Audio/ACPI Drivers – System Data Was Lost
osdjijg
Problem Description:
While installing the Intel WiFi and Bluetooth driver package (via the provided .exe installer), the system displayed a black screen. Shortly after, the system became unresponsive, and a live dump was generated (Bugcheck 0x1A8: VIDEO_DXGKRNL_BLACK_SCREEN_LIVEDUMP).
Upon forced restart, I discovered that multiple core drivers had been completely removed from the system, including:
  • NVIDIA/Intel graphics drivers
  • Realtek audio driver
  • Intel Smart Sound Technology driver
  • ACPI power management driver
The only way to recover was to reset the BIOS settings and manually reinstall all affected drivers from scratch.
Crash Dump Analysis Highlights:
VIDEO_DXGKRNL_BLACK_SCREEN_LIVEDUMP (1a8)
Arg1: 000000000000000a – Physical monitor connected but system failed to perform mode set
PROCESS_NAME: dwm.exe FAILURE_BUCKET_ID:
LKD_0x1A8_10_dxgkrnl!DISPLAYSTATECHECKER::CreateBlackScreenLiveDump
Root Cause Suspected:
This appears to be a known issue where the Intel driver installer (MSI package) mistakenly expands its cleanup scope during the "removing older drivers" phase, deleting driver registrations for unrelated devices (GPU, audio, chipset). The issue triggered immediately before the system prompted for a restart to complete the installation.
Request:
Please investigate the driver installation package's cleanup routine, specifically:
  • What criteria determine which drivers are marked for removal during installation?
  • Why does the installer target drivers outside the Intel wireless/Bluetooth category?
  • Can this be reproduced in a test environment with Windows 11 (26100) and third-party security software present?
I am happy to provide the live dump file or any additional logs if needed. This issue has caused significant system disruption and risks user data loss.
Thank you for your attention.
Goutham_intel
Hello osdjijg,
Thank you for sharing the details of your experience. We understand that encountering unexpected system behavior can be frustrating.
From our review, it is uncommon for the Intel® Wi-Fi and Bluetooth driver installation package to remove or affect unrelated drivers such as graphics, audio, or chipset components. The installer is designed to update only the relevant wireless and Bluetooth drivers.
System-specific factors, including existing drivers, operating system state, or third-party software, may sometimes lead to interactions that are unexpected during driver installation.
To assist further, we would appreciate if you could share the live dump file or any additional logs you may have. We have also sent a separate message requesting specific details—please check your personal email and share the requested information to help with troubleshooting.
For any system-specific customizations, your device manufacturer may also provide additional guidance.
Thank you for your understanding and cooperation.
Goutham
intel customer support technician
osdjijg
These are all the logs and events I found. Just a moment ago, when I uninstalled the Bluetooth driver, my Nahimic audio settings were also removed.
