Wireless
9036 Discussions
Intel Wireless Bluetooth Driver 24.50.0.4 missing AX211 chipset
Peter_Quiring
The new Intel Bluetooth Wireless Driver 24.50.0.4 is missing AX211 chipset IDs (VID_8086&PID_0033).  So drivers are stuck on 24.40.10.3
I've been having minor bluetooth issues so I reset my PC and now bluetooth is very unstable.  Most times I have to reboot to get audio to pipe thru to the bluetooth headsets.  Bluetooth Support Service sometimes fails to stop when trying to restart it (so I end up rebooting anyways).
Was hoping to upgrade drivers to see if that helps but the latest drivers seems to be missing hardware IDs for the AX211 chipset.
Laptop is Dell Pro Max 16 MC16250.
JedG_Intel
Hello Peter_Quiring,
Thank you for taking the time to provide such a detailed description of what you're experiencing.
Regarding the Bluetooth driver version 24.50.0.4, there is no issue with your system if it's showing showing 24.40.10.3 after installation. Please note that 24.50.0 refers to the driver package version, which is the latest package available. In your case, if the installation is completed successfully, the system should display Bluetooth driver version 24.40.10.3.
Additionally, since you're using a laptop, we generally recommend utilizing the drivers from the system manufacturer as this is already altered and customized by your OEM to ensure full compatibility with your device.
Please try to follow the steps below to troubleshoot the issue.
1. Download the latest OEM Bluetooth driver version 23.160.0.9, A49
2. Perform a clean installation
3. Check for pending Windows update
4. Update the BIOS to latest version 1.15.0, if not up to date
If the issue persists after performing the steps above, kindly share the information below for further investigation.
  • Before the PC reset, can you recall the Bluetooth driver version?
  • Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
  • Can you describe the Bluetooth instability in more detail?
  • Are you seeing any specific error message?
  • After rebooting, does Bluetooth work normally for a period of time before becoming unstable again, or is it unstable immediately from startup?
Jed G.
Peter_Quiring
Removed ALL driver versions except the one provided by Dell and it seems to work fine now.
I was able to do that by going into devmgmt.msc and select View -> Drivers by type and delete all Bluetooth drivers except the Dell version.
There was a dozen different versions in there.  Each version has multiple copies which I think is for the different chipsets (hardware IDs) they need to support.  So confusing...
JedG_Intel
Thank you for taking the time to provide your feedback.
I'm pleased to hear that installing the drivers provided by Dell resolved the issue. This indicates that the drivers are customized by your system manufacturer to ensure full compatibility and optimal performance with your specific system configuration.
For any future driver updates, I strongly recommend coordinating with DELL Support or using Dell-approved drivers and update tools. This will help avoid compatibility issues and eliminate any confusion about which drivers are appropriate for your system.
With the issue now resolved, I will proceed with closing this inquiry. Should you need any further assistance in the future, please submit a new question, as this thread will no longer be actively monitored.
Jed G.
