Wireless
8634 Discussions
Intel® Wireless Bluetooth® Drivers for Windows® 10 and Windows 11
Reu
The driver has not been able to be installed for several days now, the message received is shown in the attached image.
Mike_Intel
Hello Reu,
  1. What is the model of the wireless controller?
  2. What is the brand and model of your system?
  3. Are you having issues with Bluetooth connectivity?
  4. If you are getting an error message, please send a screenshot.
  5. Did you install this wireless controller on your system manually as an upgrade or is it embedded on the system?
  6. For me to check the hardware and the drivers, please help generate the SSU logs of your system. Kindly refer to the link below on how to generate the logs:
Michael L.
Reu
Good morning Michael L.
Thank you for the quick reply,
I also tried reinstalling the driver today: Intel® Wireless Bluetooth® Drivers for Windows® 10 and Windows 11.
It doesn't allow me to upload the 2 photos, so I'm attaching a copy.
(Attached is a picture of: SSU64 and another picture of the driver details).
Thank you in advance Michael L,
Have a nice day
Reu
1.Bluetooth Drivers:
Intel® Wireless Bluetooth® Drivers for Windows® 10 and Windows 11*
Installation failed
2025-08-26 7:34 AM
Description:
Installs Intel® Wireless Bluetooth® version 23.160.0 Driver version varies depending on the wireless adapter installed.
Version:
23.160.0.9Release date:
August 12, 2025Size:
64.63 MB
2. SSU Scan:
Mike_Intel
Hello Reu,
Thank you for the update.
Based on the SSU logs, you are using Intel® Wireless-AC 9462.
Can you try to manually download and install the Bluetooth driver?
Kindly refer to the link below for the download link of the latest Bluetooth driver:
Let me add, in that link under description, there is an added instruction:
  • For PCs with Intel® Wireless-AC 9560, Intel® Wireless-AC 9462, Intel® Wireless-AC 9461: Before Upgrading from 23.10.x.x—23.50.x.x versions to this 23.160.0 driver, the user needs to disconnect all the Bluetooth® devices and unpair all the previously paired devices in the PC. Once the upgrade is complete, the user can repair the devices and connect them. Fixes for PCs with Bluetooth® drivers prior to 23.10.0 can be upgraded to 23.160.0.
Michael L.
Reu
Good morning Mike,
I have already tried this and again today as per your request, attached is a screenshot of the message,
You can see that the message is: "There is already another installation in progress.........."
Is there an option or way to see and close the other installation that is already in progress in the background?
I would like to add that I just turned on the computer and immediately downloaded from the link you provided and as mentioned,
there is still an installation process that I was unaware of.
Thanks for the help.
Reu.
Mike_Intel
Hello Reu,
Please reboot your system first and make sure there is no other installation process running in the background.
If you are using Intel DSA, you may try to uninstall it and reinstall it after done with the manual installation of the Bluetooth driver.
Michael L.
Reu
Thanks again Mike_Intel!
I did everything as you wrote.
I still have a problem of " installation process running in the background"
Maybe you can help me find and close the Intel installation file that is running in the background
and does not allow me to install the new driver :
BT-23.160.0-64UWD-Win10-Win11?
Reu
Mike_Intel
Hello Reu,
Kindly try the steps in the link below and check if this will help you. Once done, please update me if you are still having the same issue.
Installation Errors While Updating Bluetooth Drivers
Michael L.
Reu
Good morning Michael L and thanks for the help.
I downloaded from the link you gave:
Download and Save the Latest Drivers for Your Intel Wireless Adapter. " Bluetooth® ,and WiFi There is no change,
still writes that there is software that runs in the background so the installation cannot be completed.
Intel has software that does test and closes the open file or scan and file repair?
Thanks for help,
Thanks again.
Reu
Mike_Intel
Hello Reu,
Let me share this thread since you have a similar issue. This issue was fixed so you may also try the steps in the link:
Solved: Intel DSA Setup - Intel Community
Lastly, you may also seek assistance from the manufacturer of the laptop or Microsoft to further check the programs running in the background.
Michael L.
Mike_Intel
Hello Reu,
Michael L.
Reu
Intel® Driver & Support Assistant — Waterfox 05_09_2025 6_30_23.pngIntel(R) Wireless Bluetooth(R) Setup 05_09_2025 6_27_04.png
Good morning Mike_intel!
As you can see the number of times I'm trying to install the update and after
I have made all your recommendations I continue to get the message that is also attached to the response.
I am still in the same iSSUE!
Have a nice Day.
Reu!
Mike_Intel
Hello Reu,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello Reu,
I sent an email in the email address associated with your profile to provide an update and how we can proceed with this case. Please check your inbox.
Michael L.
