I have upgraded my AX210 drivers to 22.80.1.1 for my Windows 10 platform. The device does not see 6GHz SSIDs anymore. My hardware platform does not support Windows 11, so I would like to understand if there will be a fix for this anytime soon. I would like to use the latest drivers for better performance. I tried to back rev the driver one release after another and the last release that works for 6GHz is 22.50.1.1.
I also made sure that the registry setting Is6GhzBandSupported is set to 1.
I tried with the Netgear RAXE500 as well as the ASUS AXE11000 with their latest firmware versions.
I am using Windows 10 21H1 release 19043.928 - October 10/12
Please let me know if there is a solution.
Hello N2692
Thank you for posting on the Intel️® communities. Please share with us the following information:
- Do you experience any Bluetooth issues?
- Is this a laptop or desktop system?
- Is this issue happening at home, office environment or both?
- Is this a new computer? If so, have check with your system's OEM for validated drivers or support on known issues related to the symptoms experienced?
- Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
- Have you checked if this issue happens on different networks?
- What steps do you take to reproduce your issue?
- Have you installed any recent software or hardware in your system?
- Have you rebooted your access-point, router, modem?
- Do other devices still see the network?
- Intel® System Support Utility (Intel® SSU) results
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
David G
David G.
David G.
