Wireless
8606 Discussions
Is Intel going to stop making carded wifi chipsets?
EEtna
See, the Skull Canyon NUC is using a soldered down 8260. This is not a problem for most people using Windows, but for others on alternative operating systems like Linux, new hardware often is not recognized by the latest kernel and needs at least a couple of releases or more before getting supported. In such cases, the option to remove an existing WiFi card and replacing it with an older card compatible with the current kernel is extremely useful.
Skull Canyon continues a not-very-optimistic trend that may very well affect mini-PCs and mITX boards in the future. Is Intel planning to go the soldered route with regards to WiFi hardware? I surely hope not.
Etnaz,
Currently there are two form factors for this adapter as you can confirm here: Intel Dual Band . One is soldered down and the other is an M.2. Unfortunately, regarding the ones that come soldered down, at this time, there is no information if this will change in the future.
Let us know if you have any more questions or doubts.
Aleki
Etnaz,
We haven't heard from you in a while so we would like to know if the information we sent you above helped you clarify your doubts or if there is anything else we can do to assist you.
Aleki
