The installer reported that "Killer Performance Driver Suite UWD.msi" can't be found at:
C:\Users\<Username>\AppData\Local\Temp\{B1CF7EEC-329D-4065-870C-D524657A6BFE}\
thus, unable to uninstall the old version of the app,
and the Intel® Driver & Support Assistant ended with error code 1603.
Hello carecynthia,
Thank you so much for reaching out on the Intel Community Forum
Greetings from Intel customer support
Thank you for reaching out and for providing the detailed error information. I understand how frustrating it can be when the installation or uninstallation process fails due to missing MSI files, especially when it also results in Intel® Driver & Support Assistant error code 1603. I truly appreciate your effort in sharing the exact error path and details.
Please be assured that I will do my best to assist you in resolving this issue.
Based on your query, I would like you to follow the steps below carefully:
Steps to uninstall the default Intel® Killer Performance Driver Suite UWD:
- Open the Run menu by pressing Windows key + R
- Type appwiz.cpl and press Enter or click OK
- Locate Intel® Killer Performance Driver Suite UWD
- Select it and uninstall the application
- Restart the system
Steps to install Intel® Killer™ Performance Suite:
- Go to the Intel® Killer™ Performance Suite download page
- Download and install the latest version
- Restart the system after installation
- Verify installation using Intel® Driver & Support Assistant (Intel® DSA) to ensure everything is up to date
Thank you for your patience and cooperation.
Best Regards
Chawan
Thanks for the reply, yet Intel® Killer Performance Driver Suite UWD no longer exists in appwiz.cpl, which is the reason I'm stuck and need assistance.
Supposedly, the app is already uninstalled; however, a newer version can't be installed due to "unable to uninstall the old version of the app".
My guesses are, an uninstall attempt failed at some point and left some unexpected traces in the system so that reinstalling also fails.
But, unable to find "Killer Performance Driver Suite UWD.msi" at "C:\Users\<Username>\AppData\Local\Temp\{B1CF7EEC-329D-4065-870C-D524657A6BFE}\" also appears to me more like a remote issue that some resources can't be downloaded from the server.
The attached file is the SSU report.
Best Regards
Hello carecynthia,
Thank you for your response and for sharing the detailed information along with the SSU report. Please allow us some time to work on this. I will review the details and get back to you with an update on the same.
We appreciate your understanding and co-operation throughout the process.
Thank you for being a valued customer of Intel.
Best Regards
Chawan
Hello carecynthia,
Thank you for your patience. Please be informed that We have shared an update with you via email regarding your request. Kindly check your inbox and request you to revert with your response so we can assist you further.
Chawan
Intel Customer Support
Hello Carecynthia,
I hope you are doing well.
We are following up on the previous email shared regarding your request. Kindly check your inbox for the update we provided and revert back with your response at your earliest convenience.
Your confirmation will help us proceed further and assist you more effectively.
We appreciate your cooperation and understanding throughout the process.
Chawan
Hello carecynthia,
Thank you for your patience. To further assist you with the issue, we recommend following the troubleshooting steps outlined in the Intel support article below:
Using the Microsoft Tool* to Fix Intel® Killer™ Performance Suite...
Kindly perform the steps mentioned in the article, which include clean reinstallation of the wireless drivers and related settings adjustments.
After completing the troubleshooting, please let us know the outcome and whether the issue still persists.
This will help us continue the investigation and guide you with the next steps if required.
Thank you for your cooperation. I look forward to your response.
Best Regards
Chawan
Hi carecynthia,
I wanted to follow up regarding the troubleshooting steps shared earlier, including the Intel support article for the Intel® Killer™ Performance Suite and the clean reinstallation of the wireless drivers.
Could you please let us know if you had the opportunity to complete the steps, and whether the issue still persists after performing the recommended changes?
Your feedback will help us continue the investigation and guide you with the next appropriate steps if required.
Thank you for your time and cooperation.
Best Regards
Chawan
Tried the troubleshooting steps but no luck.
Neither Intel® Killer Performance Driver Suite UWD nor {B1CF7EEC-329D-4065-870C-D524657A6BFE} appeared in the installing or uninstalling list of the tool.
The issue still persists.
Best Regards
Hi carecynthia,
Thank you for the update, and I’m sorry to hear that the issue is still persisting despite the troubleshooting steps.
I understand the situation and appreciate your efforts in trying the previous recommendations.
At this point, to further isolate and resolve the issue, I would recommend proceeding with a remote assistance session so we can check the system directly and identify what is causing the behavior.
If you are available, please let me know a convenient time, and I will share a quick assist code to connect with your system.
We will do our best to help you resolve this as quickly as possible.
Best Regards
Chawan
Hello Carecynthia,
I hope this email finds you well.
Thank you for your continued patience — I completely understand how disruptive connectivity issues can be, and I want to make sure we get this sorted out for you as quickly as possible.
As part of our ongoing troubleshooting, I'd like to ask you to try the following steps:
Step 1 – Check and Update Intel® Management Engine (ME) Drivers Please verify whether your Intel® Management Engine drivers are up to date. Outdated ME drivers can sometimes interfere with wireless functionality. You can download the latest version from your system manufacturer's (OEM) support page or directly from the Intel® Download Center.
Step 2 – Uninstall Intel® Killer™ Performance Suite (IKPS) Please uninstall the Intel® Killer™ Performance Suite from your system. You can do this by navigating to Settings → Apps (or Control Panel → Programs and Features) and removing Intel® Killer™ Performance Suite from the list.
Step 3 – Reinstall the OEM Wireless Driver Once IKPS is removed, please install the wireless driver available on your system manufacturer's support page, as OEM-optimized drivers are often best suited for your specific hardware configuration.
Step 4 – Try the Latest Generic Intel® Wireless Driver (if needed) If the issue persists after trying the OEM driver, please download and install the latest generic Intel® wireless driver from the Intel® Download Center:
Please implement and troubleshoot the recommended steps above, and get back to us with your outcomes so we can assist you accordingly.
Please feel free to reach out if you have any questions or run into any difficulties along the way. We're here to help!
Tharun
