The Bluetooth is not installed with WIFI 7 BE211 320Mhz - DRIVERS 24.40.0 - Error code 43.
WiFi-24.40.0-Driver64-Win10-Win11.exe
Hi guardao,
I understand you're experiencing difficulties with Bluetooth functionality despite having the Wi-Fi driver version 24.40.0 installed. Error Code 43 typically indicates that Device Manager cannot start the hardware device, and this commonly occurs after Windows updates that include Wi-Fi or Bluetooth components.
To further troubleshoot the issue, please try to follow the outlined steps below.
1. Install all available Windows Updates.
2. Perform a Clean installation of Bluetooth drivers: How to Perform a Clean Installation of Bluetooth Drivers
- Go to Device Manager.
- Expand the Network Adapters category.
- Right-click your Intel Bluetooth Adapter and choose to uninstall it.
- Make sure to the option to Delete the driver software for this device is selected.
- Repeat steps A through D until the the option to Delete the driver software for this device is greyed out.
3. Once the driver is uninstalled, proceed to install the latest driver available 24.40.0
4. Reboot the PC
5. Update system BIOS to the latest version, or reset BIOS to defaults
6. Perform a cold reboot
Laptop cold reboot with removable battery
- Turn off the laptop, and unplug the power cord.
- Disconnect any peripheral devices then remove the computer from any port replicator or docking station.
- Remove the battery from the computer.
- With the battery and power cord unplugged, press and hold the Power button for approximately 15 seconds.
- After you drain the capacitors, re-insert the battery, then plug in the power cord. Leave peripheral devices disconnected.
- Turn on the laptop.
Laptop cold reboot with a non-removable battery
- Turn off the laptop.
- Disconnect the AC adapter.
- Disconnect all nonessential peripheral devices, such as printers, scanners, external hard drives, and USB flash drives.
- With the AC adapter unplugged, press and hold the power button for approximately 15 seconds.
- Reconnect the AC adapter then turn on the computer.
Desktop cold reboot
- Turn off the computer.
- Unplug all the cables from the back of the computer.
- Press and hold the power button for 20 seconds then release it to discharge remaining power. Clearing the CMOS battery is optional.
- Reconnect all cables back again and turn on your computer.
You may also check this article for more information: Error Codes 10, 22, 28, 31, 43, or 45 in Device Manager for Bluetooth® or Wireless (Wi-Fi) Devices
If the issue persists, please share the additional information below for further investigation.
1. Have there been any recent system changes?
2. Where are you seeing the error code 43, is it on Device manager? Kindly share a screenshot of the error
3. Is this a pre-installed wireless card or self-integrated?
4. Was this working before with a previous driver version? If so, what is the driver version?
5. What is your exact system model and manufacturer?
6. Screenshot of Wireless adapter model on Device manager > Network adapters.
Best regards
Jed G.
Hi, Jed G.
Thank you for your response.
I've tried all of possibly above solution and nothing works.
My system:
LENOVO ThinkPad E16 Gen 3 - Intel Core Ultra 7 255H - BIOS R30ET57W(1.57 )
Windows 11 Pro - 25H2 - SO 26200.8524
Wireless Card - Killer Wi-Fi 7 BE1775i 320MHz Wireless Network Adapter (BE211NGW) - DRIVER 24.40.0.4 - BLUTOOTH 6.0
Device Instance Id - PCI\VEN_8086&DEV_7740&SUBSYS_17751A56&REV_00\3&11583659&1&A3
This is a new OEM wireless card that I bought and install two months ago.
Previously I also bought a card BE201 version.
The BLUETOOTH was working with the BE201 card version, but as soon I changed to the new Killer Wi-Fi 7 BE1775i all I have is an CODE 43 response and the Intel drivers - BT-24.40.0-64UWD-Win10-Win11.exe - are not capable of fixing it.
Looking for a solution,
Best regards
Guardao
Hi guardao,
Thank you for sharing all this information. I really appreciate the effort and patience you’ve shown in working through the extensive troubleshooting steps I suggested.
I would just like to share that before you install/change the Intel® Wireless Adapter in a system, you must contact the system manufacturer to determine if the Intel® Wireless Adapters you plan to install is approved for use in your system and country. You are required to follow the manufacturer's post-approval requirements.
Since you have already performed the integration, it is also important to understand that it may not work due to hardware or software compatibility issues or dependencies.
You may also check our public article here: Regulatory Information Regarding Wireless Hardware Installation or Upgrade
To further investigate this, kindly provide the details below.
1. Where are you seeing the error code 43, is it on Device manager? Kindly share a screenshot of the error.
2. Share a screenshot of the Wireless adapter model on Device manager.
- Device manager > Network adapters
Best regards
Jed G.
Hi Jed G.
The problem relies with the BLUETOOTH installation.
The WIRELESS is working without any problems.
1 - BLUETOOTH code 43.
2 - WIRELESS adapter Killer BE1775i.
I hope this helps.
Thank you.
Guardao
