Wireless
9036 Discussions
Killer Software Update
BlackGuard
The Intel update tool tells me the there are Wifi and Ethernet driver updates along with the Intel® Killer™ Performance Suite (which should have all the drivers).
I installed the said version but theI Intel updater tells me that there are still updates. Trying to install the suite again end in the installer asking me if I want to uninstall the installed version.
Ok. Let'ts take the drivers from here the Dell update site
Wifi driver ok, Ethernet driver comes along with the Ethernet suite which is incompatible with the generel Killer performance suite.
Used a Killer uninstaller to get rid of everything, restarted the computer and tried the performance suite again. Intel updater keeps telling me that there are newer drivers and the my software is not up to date.
Maybe related to an error from the Windows store.
Part of the whole thing is the Killer Controll Center
Can'T be installed because of a 0x803FB005 error.
What should I do?
The drivers from Dell are the wrong or older ones and incompatible with the performance suite and for whatever reason the Killer Control Center cant be installed.
Next I uninstalled every network driver until only the standard one from Microsoft were left.
Installed the Killer suite but nothing changed. MS driver in place, no newer driver to choose from.
Donwloaded the driver packages from Dell and instead of installing them (as they come along with the wrong Killer suites) extracted the packages and installed the drivers from the folder via device manager.
Now I have a E3000 Ethernet driver from Killer in place
The AX1650 driver is from intel though.
The control center can't be installed with the same error.
Tried via appx file and this error came up:
RivetNetworks.KillerControlCenter_3.1624.813.0_x64__rh07ty8m5nkag kann von Windows nicht installiert werden, da es von einem Gerätetreiber abhängt, der nicht gefunden werden konnte. Einer der folgenden Gerätetreiber muss installiert sein: {[Intel_Corporation-KillerNetworkComponent.inf, 3.1624.813.0]} (0x80073cfd)
in English:  Intel Cooperation Killer Network Component must be installed.
Gosh. The drivers are in place.
Tried the hint here to no avail as well
https://www.intel.com/content/www/us/en/support/articles/000058906/wireless/wireless-software.htmlhttps:/www.intel.com/content/www/us/en/support/articles/000058906/wireless/wireless-software.html
BlackGuard
After what felt aeons Intel has provided a working Killer Performance Suite in version 40.25.1010.1818
It contains a 1650 driver in version 24.0.2.1 (can be found here: "C:\Program Files\Killer Networking\Killer Control Center\Production\Windows10-x64\Netwtw08\Netwtw08.INF")
The Killer Control Center works with that one.
BlackGuard
PS.: Uninstalled all network divers again via the device manager until only the standard ones from Microsoft were left and Installed the Killer Suite with the driver only option. Afterwards no newer drivers were found. Only the one from Microsoft.
BlackGuard
Tried to install another version but the app can't be installed as well
BlackGuard
the latest version KillerPerformanceSuite_36.24.12162_Win10-11x64 doesn't do sh#t as well.
no drivers are installed.
had the device manager opened during installation. nothing happened there.
checked afterwards. same drivers as before.
BlackGuard
Through a driver updater tool I was able to get my Kille WiFi Driver to 23.100.0.4 but can't install the Control Center app anyhow.
BlackGuard
Same issues with UWD Suite 36.25.2193
BlackGuard
Found the issue:
According to the installer Logs this folder has the inf files installed
in there there are these two folders
Neither of them contains a 1650 driver.
Intel has just forgotten the compatible drivers.
WTF?
BlackGuard
