Wireless
8965 Discussions
Linux Kernel Error
knopper
I am getting repeated kernel logs of this error:
alex@fedora:~$ sudo dmesg --level=err | grep -i iwlwifi
[ 14.265580] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 15.445441] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
[ 15.737818] iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
System info:
System:
Host: fedora Kernel: 6.10.8-200.fc40.x86_64 arch: x86_64 bits: 64
compiler: gcc v: 2.41-37.fc40 clocksource: tsc
Console: pty pts/1 wm: gnome-shell DM: GDM v: 46.2 Distro: Fedora Linux
40 (Workstation Edition)
Machine:
Type: Laptop System: Razer product: Blade 15 (2022) - RZ09-0421 v: 8.04
serial: BY2222M73501760 Chassis: type: 10 serial: N/A
Mobo: Razer model: CH580 v: 4 serial: N/A part-nu: RZ09-0421EED3
uuid: 66376534-3534-6236-3161-656334366230 UEFI: Razer v: 2.06
date: 11/01/2023
Network:
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
Simultaneous Dual Band Wi-Fi 6E AX1690i 160MHz 2x2 driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Earl_Intel
Hi knopper,
I'm sorry to learn that you are experiencing issues with your system.
No worries, I will further check on this internally and provide an update on this thread as soon as possible.
Earl E.
Earl_Intel
Hi knopper,
Thank you for patiently waiting.
To further investigate the issue, kindly provide the details on the list below:
1. When did this issue first occur?
2. Is the adapter the original one that came pre-installed in your system, or have you recently changed or installed a new adapter?
3. Was Windows 11 the previous operating system on the computer? If so, what prompted you to switch to Linux? According to the specifications, the original OS is Windows 11.
For troubleshooting, please try installing the firmware using our Linux* Support for Intel® Wireless Adapters article.
Earl E.
knopper
Hello Earl,
I have had this error message for a while, I switched to Linux a year ago and can't remember a time I did not have this error.
The adapter is the one that came with the laptop. Lastly windows 11 was the OS that came on the device. I switched to Linux for personal reasons
Earl_Intel
Hi knopper,
Thank you for sharing this information, noted on this.
I just want to confirm if you were able to try the troubleshooting I provided on the previous post? About installing the firmware using our Linux* Support for Intel® Wireless Adapters.
Earl E.
knopper
Hey Earl,
This one is actually resolved. It looks like it was addressed in a recent firmware update from late last year. My apologies for continuing the conversation on this.
Earl_Intel
Hi knopper,
Thank you for sharing this update with us, I'm happy to know that the issue is now resolved by the firmware update.
If ever the issue persists, its best if you try to contact your OEM for additional troubleshooting since they provide the firmware updates.
If you need further assistance, please submit a new question as this thread will no longer be monitored.
Earl E.
