Wireless
8692 Discussions
Looking for Driver and Firmware Documentation for the AX210
OddlyDoddly
My organization is doing Wi-Fi sensing research and is using the AX210. We've found modified versions of drivers that allows the extraction of Channel State Information from the AX210. However, we are looking for more in-depth information on the Open Source iwlwifi driver and firmware associated to the AX210. I've been digging around the net for the documentation, and assume its out there somewhere given that i've found 2 projects modifying intel's iwlwifi drivers. Does anyone know where I can get software, firmware, and hardware documentation for intel's ax210's driver and firmware?
Mike_Intel
Hello OddlyDoddly,
Before we proceed, let mask. Where did you get or heard about the modified drivers?
Michael L.
Mike_Intel
Hello OddlyDoddly,
Michael L.
Mike_Intel
Hello OddlyDoddly,
I am sending another follow up on the information that I requested.
Michael L.
Tonny_
Hi @Mike_Intel,
I'm not able to give you answer on the question addressed to the author of this topic but on the other hand could you answer on the main topic addressed to you about documentation of Intel linux driver, firmware, can it be find somewhere?
regards
Tomek
