Wireless
8859 Discussions
Network Adapter
JGibs2
I was looking for a supported network adapter. I have an
Intel Centrino Advanced-N 6200 AGN which was the same dimensions as my original
adapter in my Asus N61Jq-B2 laptop with Windows 7. The reason I switched was
because mine had only one antenna and could get only 50 Mbps internet speed. I
wanted to get at least 100 Mbps. I get over 200 Mbps wired. I think Intel Centrino Advanced-N 6250 is still
supported, but I don't know for how long and I don't know if it would have the
same dimensions. I would appreciate any help in this matter. I want to be sure
I can stay supported with updating the drivers.
AlHill
You will not be supported if you attempt to do this yourself.
Please read these two documents:
https://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005687.html Regulatory Information Regarding Hardware Installation or Upgrade
https://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005846.html Why Doesn't My Laptop Recognize My New Intel® Wireless Adapter?
Doc
Hi Jpgibs,
Thank you for posting in Wired communities. I will forward your inquiry to the wireless support team since your product is a wireless card.
Sharon
Hello jpgibs,
As mentioned by Doc, we don't support custom wireless integrations. Some laptop manufacturers limit which adapters can be installed in your system via a white list. Because of this, our best recommendation is to work with your system OEM to find a suitable replacement part, and if possible, to purchase this new adapter from them. This way you can avoid compatibility issues, and won't end up buying an adapter intended for a different branded laptop.
The Intel® Centrino® Advanced-N 6200 was manufactured in the PCIe Half MiniCard (HMC) form factor, which has now been superseded in current adapter models by M.2. All HMC adapters have reached the End of Life (EOL) status, which signifies that they are no longer being manufactured. While EOL adapters are still included in newer driver packages, these may not always include updated drivers for these models.
Both the Intel® Centrino® Advanced-N 6200 and the Intel® Centrino® Advanced-N 6250 have been discontinued and reached their End of Interactive Support (EOIS) life cycle status. You can verify this in our https://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000006507.html Customer Support Options for Discontinued Intel® Wireless Products article.
If you're looking for a 2x2 antenna, HMC adapter, which is only EOL and not EOIS, we can recommend checking the following adapters with your computer manufacturer. Before purchasing, make sure to confirm the form factor, as some of these were made in both M.2 and HMC:
- https://ark.intel.com/compare/59471,66889,66890,75439 Product Comparison List.
We hope this information helps.
Carlos A.
