Wireless
8636 Discussions
Not detecting newer driver available - Intel Driver & Support Assistant
TFurs
I have a Lenovo Yoga (Win10 1803) running the Intel Driver & Support Assistant v3.5.1.7 and the system has an Intel Dual Band Wireless-N 7260. The issue is that the Intel Driver & Support Assistant is not detecting when there is a newer WiFi driver available:
* Tested the Intel Driver & Support Assistant with Firefox 62.0.2, Edge (1803) and IE11 (1803) - all 3 browsers report that "Your Intel® software is up to date."
* The Intel 7260 is using this driver -> Version: 20.70.0 (Previously Released) Date: 7/31/2018, https://downloadcenter.intel.com/download/27989/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?product=75440
* However, there is a newer driver available -> Version: 20.80.0 (Latest) Date: 9/11/2018, https://downloadcenter.intel.com/download/28143/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-10?v=t
* Lenovo no longer publishes updated drivers for this device so I rely on the Intel Driver & Support Assistant to keep the drivers up to date (usually needed when a new version of Windows 10 is released every 6 months)
Because the Intel Driver & Support Assistant is showing the Intel 7260 WiFi is up to date, I wanted to see if you could check the attached Intel Driver & Support Assistant logs to see why it isn't seeing the newer driver. Also, let me know if there are any other logs I can send over. Thanks!
Hello TF14
Thank you for joining the Intel® community.
Steps for a clean install of Intel® Driver & Support Assistant:
Uninstall the current versions using the DSA uninstaller located here:
Intel® Driver & Support Assistant Uninstaller Version: 1.0.0.2 (Latest)
https://downloadcenter.intel.com/download/28149/Intel-Driver-Support-Assistant-Uninstaller https://downloadcenter.intel.com/download/28149/Intel-Driver-Support-Assistant-Uninstaller
Once you have uninstalled the previous version; install the latest version of Intel® Driver & Support Assistant:
https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant?product=128824 https://downloadcenter.intel.com/download/24345/Intel-Driver-Support-Assistant?product=128824
Bear in mind that the drivers provided by Intel are the generic drivers for your system, we recommend to test/use the driver provided the Original Equipment Manufacturer (OEM) due to those are customized for your system.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
Hello TF14
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
