Wireless
8711 Discussions
PLACA WIFI 8260
noelbarreto
TENHO UM NOTEBOOK DELL INSPIRON 5547, PROCESSADOR i7, CUJA PLACA DELL WIRELESS 1707 NECESSITA SER TROCADA. A PLACA INTEL 8260 PODE SUBSTITUÍ-LA, É COMPATÍVEL COM O PROCESSADOR E CABE NO SLOT?
OBRIGADO.
AlHill
First, do not be afraid to release the CAPS LOCK.
Then, contact DELL and ask them about a compatible replacement.
Esteban_D_Intel
Hello noelbarreto,
Our support is only provided in English. Therefore, we may not be able to translate screenshots attached to the thread.
To answer your question; Performing wireless integrations is subject to country-specific legal regulations. Before installing or changing the Intel® Wireless Adapter, Intel recommends that you contact the system manufacturer to obtain approval, step-by-step instructions, or support. It is worth mentioning that the integration may or may not work due to the following reasons:
1. Hardware/software compatibility issues or dependencies.
2. Manufacturer limitations.
3. Driver limitations.
Support article: Regulatory Information Regarding Wireless Hardware Installation or Upgrade
The information provided by AlHill is correct, for this matter you would need to contact DELL* for further assistance. We would strongly recommend checking with them before making the upgrade.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
Intel Technical Support Technician
