Wireless
9047 Discussions
Problem Installing Driver
NP1
Appreciate any help.
My first post sorry apologise for any error in advance.
Problem
Using intel driver update, found update for intel proset / wireless software for Bluetooth.
I downloaded and installed but failed.
See attached debug file log for details.
This I what I think the problem is as listed in log.
DriverUpdateUI.exe Information: 0 : IDUU-Install: Couldn't find 32 bit subkey. Trying 64 bit.
DriverUpdateUI.exe Information: 0 : IDUU-Install: Couldn't find registry subkey. We're done here.
Help
Can someone please assist in getting update to install, thanks.
regards
Corca!!!
IUman
If you have some problems updating this driver with the Intel® Driver Update Utility please try manually, you can download the driver at:
https://downloadcenter.intel.com/product/66890/Intel-Centrino-Advanced-N-6235-Dual-Band https://downloadcenter.intel.com/product/66890/Intel-Centrino-Advanced-N-6235-Dual-Band
If the system you have is an OEM system HP, DELL, Toshiba etc, I strongly recommend updating the driver from your system manufacturer website. Please be aware that the proper driver will be located at that website.
Please provide me with your system model or if you purchase the wireless card separate.
NP1
Hi Ivanu
Tried option one manual download and removed previous and the installed.
This installed it as shown in pic below in my programs and features
But when I run utility and check in my settings it shows below.
The utility tells me its out of date.
Option 2 OEM Website
My system was windows 8 then upgraded to windows 8.1 and then windows 10.
If I go to my OEM I have two drivers to pick from see below, should I install one of them?
Any help appreciated.
regards,
Corca!!!
NP1
Hi Ivanu
My Laptop is a Metabox P170EM
Follow link
http://www.metabox.com.au/drivers.asp Metabox Driver Downloads
NP1
Hi Can someone assist please.
Nick.
IUman
Hello Corca,
Please be aware that Intel provides generic versions of drivers for general purposes. Your computer manufacturer may have altered the features, incorporated customizations, or made other changes to your driver. Intel recommends you contact your computer manufacturer for the latest system specific updates and technical support information as they are more familiar with you system configuration and how the components interact with each other.
Also, I recommend checking with your system manufacturer about the Windows 10 compatibility with your system.
NP1
Thanks, got it.
Apprecaite the help.
