Hi.
We are currently in the process of integrating the BE200 into our system.
So We need BE200's certificate, RF Test Report, and RF EMC Report to get certification of our products.
Representatively, FCC, CE, Japan, China, India etc., including KC, are needed first.
If possible, can I get documents from all countries certified for the product?
It would be great if you could send me these documents.
Thanks in advance.
Hi tiger12,
Thank you for reaching out to the Intel Community Forum. I appreciate your message and want to assure you that I’m here to assist with your request.
I understand you're in the process of integrating the BE200 into your system and require certification documents. I’ll look into your concern regarding these documents, and I’ll keep you updated as I gather the necessary information.
If you have any additional questions or need further assistance, please don’t hesitate to contact us.
Kent Russel P.
Hi tiger12,
Thank you for your patience.
You can obtain the required regulatory documents and certificates for the BE200 from the following link: Regulatory Documents for Intel® Wi-Fi 7 Series Products
Regarding the test reports, please note that ICS is unable to provide certification for the requested country. RF certification is typically dependent on the antenna or the system configuration. Since Intel only secures modular-level approvals, it is the responsibility of each customer to obtain final certification based on the specific antenna or host system used with the Intel Wireless Adapter.
We recommend reaching out to Dekra for assistance in evaluating whether additional testing is necessary and to help you obtain final certification using Intel’s module test reports and certificates.
The enabled party is one of the initial modular type approval labs with experience in Intel test tools and country-specific certification processes based on the modular approach. With their support, we expect your certification process to be smooth and efficient.
If you have any further questions or need additional assistance, please don’t hesitate to contact us.
Kent Russel P.
Dear Mr.Kent Russel P.
We also have a similar request for the Intel Wi-Fi 7 BE200NGW, and our customer is located in Switzerland. Do you have a contact person we can reach out to in order to obtain the test reports and test tool?
Thank you so much.
Good day.
After discussing with Dekra, they can provide certficates but regarding test tool, they said we still need your help.
- ANT - Antenna Tool
- 2DRTU - Diagnostic and Regulatory Testing Utility tool
I tried to search it in "intel rdc" but couldn't find it. Thank you so much.
Hi tiger12,
I just wanted to follow up and check if you’ve had a chance to review the information I shared previously. Your feedback is important, and I’d appreciate it if you could share your thoughts at your earliest convenience.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
Hi tiger12,
I hope you're doing well. As I haven’t received a response, I will proceed to close this inquiry. Should you require further assistance or have additional questions, please feel free to submit a new request. Kindly note that this thread will no longer be monitored once closed.
Kent Russel P.
