Hello:
I am currently using a DELL Latitude E6540 Laptop, I live fulltime in an RV Park.. The WiFi Signal here is terrible, with the Intel Wireless-N 7260 Mini PCIe card inside my RV I got between 48% and tops of 55% Signal Strength. After extensive research on Wifi Signal Boosters, etc., I found not much worked, per say. My last resort was to install a 2.4GHz YAGI Outdoor Antenna aimed at one of the Uniquintoi Access Points, running RG-174 Coax cable from the YAGI Antenna directly to the Intel Wireless-N 7260 Mini PCIe Wifi Card, inside the Laptop. I gained fluctuation between 70% up to 85% at times, yet the Wifi Indicator on the DELL E6540 is constantly lit up.
I have ordered a Low Noise High Gain Amplifier w/SMA connectors, (RF-IN & RF-OUT males) to attach the RG-174 Coax cable w/SMA connectors at each end. The Amplifier is said to produce 1 Watt of output Power.... My Questions is... Would this 1 Watt of output Power fry the Intel Wireless-N 7260 Mini PCIe Wireless wifi Card.....???????
James.....
Hello Jimlp1,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wireless-N 7260.
Due to this product being discontinued, Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
- Discontinued Products: https://www.intel.com/content/www/us/en/support/discontinued-products.html
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
