Wireless
8871 Discussions
Technical Support Request: RF Certification Tools (DRTU) for Intel AX210 on ARM64 (Rockchip RK3588)
Dieter_Mathis
Dear Intel Support Team,
We are currently in the EMC certification phase for a project utilizing the Intel AX210D2W module on an ARM64 platform (Radxa Rock 5T, Rockchip RK3588). We are running Mainline Linux v6.18.
To complete the RF exposure and spurious emissions testing, we require a method to put the AX210 into Continuous Transmit mode. Specifically, we need to:
  1. Control TX Power.
  2. Fix Modulation/Data Rates.
  3. Set the module into a dedicated RX mode.
  4. Operate on specific channels (2.4GHz, 5GHz, and 6GHz/Wi-Fi 6E) without regulatory back-off.
Could you please provide access to the Intel DRTU for Linux, including drivers and instructions?
If there are specific iwl-debug-modes or module parameters for the iwlwifi driver to enable these lab modes in a mainline environment, please provide the relevant documentation.
Dieter Mathis
KentRusselP_Intel
Hi Dieter_Mathis,
Thank you for reaching out to the Intel Community Forum. I appreciate your message and want to assure you that I’m here to assist you with your concern. I've sent an email to your active email address for the next step of the process. To better understand the issue and provide accurate support, could you please check both your Inbox and Spam folder for my email, and once received, kindly acknowledge it.
If you have any questions or need further clarification, please don’t hesitate to reach out.
Kent Russel P.
JeanetteC_Intel
Hi Dieter_Mathis,
Let us know if you have any questions.
JeanetteC.
KentRusselP_Intel
Hi Dieter_Mathis,
Since I have not received a response from you, I will go ahead and close this inquiry for now. If you need any further assistance or have additional questions in the future, please don’t hesitate to submit a new request — I’ll be more than happy to help.
Please be advised that once this case is closed, this thread will no longer be monitored.
Kent Russel P.
