Wireless
8973 Discussions
Ubuntu not recognizing AX210
Kristofferarl
I have a problem with Ubuntu not recognizing my AX210 module.
In the settings, only wired network and Bluetooth are displayed.
No error logs are shown with
dmesg | grep iwlwifi
The following has also been tested:
* Running with versions 22.04 and 22.10.
* Have updated to kernel of version 6.1.x and 5.2.x.
* Installing latest firmware from intel.com
* Removing iwlwifi-ty-a0-gf-a0.pnvm
Right now I'm feeling kind of stuck and out of ideas to try.
Thanks in advance
/Kristoffer
DeividA_Intel
Hello Kristofferarl,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Wi-Fi 6E AX210 (Gig+).
1. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
2. Is this a laptop or desktop computer?
3. Was the wireless adapter working before?
4. Have you tested the adapter with a different operating system? If so, what was the operating system?
5. Have you checked this issue with Linux support?
Deivid A.
Kristofferarl
This is a custom built computer
Desktop
The adapter has never worked on Ubutnu for wifi. Bluetooth is working though
Both wifi and bluetooth works with Windows 10
No. This feels more firmware hardware related so I checked here first.
Any advice where I can get his kind of support for Linux ?
DeividA_Intel
Thanks for the confirmation. In order to further investigate this issue I will need the following:
1. Provide the Intel® System Support Utility report for the Linux* Operating System for more details:
2. Run the following commands and send us the outcome:
  • modinfo iwlwifi > If there is no output, then the module isn’t installed this is the distribution installation issue.
  • lsmod | grep iwlwifi > If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue.
  • To verify, please type: dmesg | grep iwlwifi > If the result is empty, the driver wasn’t initialized and this is a distribution issue. If there is a result populated, proceed with the next step.
  • dmesg | grep “no suitable firmware found!” > If the result is not empty, it means you don't have a suitable FW (api mentioned in the dmesg).
  • Please visit here: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi for supported FW, or here https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
8. If the above steps don't work, collect the debug data:
  • Type: dmesg | grep ASSERT
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging to extract dmesg and trace-cmd.
If the output has value, please collect it from the wiki FW dump too.
Also, you may find support for your Linux system in the following link: https://www.linux.org/whats-new/posts/4458106/
Deivid A.
Kristofferarl
Thanks for the reply Deivid
kri-desktop.txt
modinfo iwlwifi >>> output3.txt
lsmod | grep iwlwifi >>> output2.txt
dmesg | grep firmware  >>> output4.txt
dmesg | grep assert  >>> output5.txt
DeividA_Intel
Thanks for the reports and the outcome shared. I will proceed to check the issue internally and post back soon with more details.
Deivid A.
DeividA_Intel
Thanks for your patience. Just to confirm, please perform an update to the latest and stable kernel available.
Please let me know once you have installed the latest and most stable kernel available.
Deivid A.
DeividA_Intel
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
Kristofferarl
Hi Deivid
No this is still an issue and I have not managed to come around it.
Currently running kernel version
6.2.1-060201-generic
Have also tried
5.4.0-12.15-generic and others without luck
Could you please share your findings from my logs?
Thanks!
regards,
Kristoffer
DeividA_Intel
Thanks for the confirmation. I will proceed to continue with the investigation and I get back to you with further details as soon as possible.
Deivid A.
DeividA_Intel
Thanks for your patience. Based on the dmesg log, the WLAN failed to be initialized properly. This could be related to a compatibility issue on this Kri-embedded computer under Linux.
At this point, I recommend you the following:
1. Consider disabling PCIe ASPM on AX210.
A brief introduction about ASPM can be found here: https://wireless.wiki.kernel.org/en/users/documentation/aspm
- The section 'Enabling ASPM with setpci' provides steps to look for the Link Control Register of the PCIe device, and provides an example to disable ASPM:
# Disables ASPM, enables only L0
sudo setpci -s 00:1c.1 0x50.B=0x40
(Note. The ASPM value will be automatically re-enabled after the system reboot.)
2. If the setpci method doesn't work, please try to update the BIOS to the latest version. Or try to access BIOS and disable settings related to 'PCIe power save' or 'PCIe ASPM (Active State Power Management)'
If the previous steps did not work, the last recommendation would be to check with the computer manufacturer for further investigation.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
Kristofferarl
Thanks for the awesome support!
I have now been able to figure out what caused the issue.
Apparently Ubuntu does not support when "hot plug" is enabled on the current PCIe bus that the card is connected to. Disabling it solved the issue.
On that not its exactly the opposite in Windows10 where i get blue screen when its disabled.
Happy Easter!
regards,
Kristoffer
Waleed2660
Hi @Kristofferarl ,
Thanks for sharing that fix. I ran into same problem & couldn't get it to work. I ended up adding a config to grub's config file so that it only disables the hot plug when booting into Ubuntu & won't impact anything when I boot into windows.
Putting down the instructions for anyone else who might run into this issue with Dual Boot:
  1. Edit Grub Config:
    1. sudo nano /etc/default/grub
  2. Add "pciehp.pciehp_force=0" to:
    1. GRUB_CMDLINE_LINUX_DEFAULT="quiet splash pciehp.pciehp_force=0"
  3. Reboot & your Wifi should start working!
Thanks very much!
Waleed
