Wireless
8871 Discussions
Wi-Fi 6 AX200 cannot start
egburr
Current driver installed: WiFi_21.80.2_Driver64_Win10.exe
Driver Provider: Intel
Driver Date: 2/25/2020
Driver Version: 21.80.2.1
Attempted to uninstall and try driver version 21.70.0, by uninstalling the device and software fails to uninstall the driver. A reboot brings the device back with the current driver level. Trying to install the older driver is rejected because the newer driver is present.
Device Manager:
Device status:
This device cannot start. (Code 10)
{Operation Failed}
The requested operation was unsuccessful.
Event Viewer, System Log:
(I)7036 The \Device\NDMP21 service entered the Intel(R) Wi-Fi 6 AX200 160MHz state.
(I)7005 - SAR value max TX power (WRDS)
(I)7010 - driver enabled (miniport init)
(I)7017 - secure boot (SB) configuration
(E)5011 Intel(R) Wi-Fi 6 AX200 160MHz : A required parameter is missing from the registry.
(E)5002 Intel(R) Wi-Fi 6 AX200 160MHz : Has determined that the network adapter is not functioning properly.
(E)10317 Miniport Intel(R) Wi-Fi 6 AX200 160MHz, {b0365bd9-30cd-487b-a441-80a38534e684}, had event Fatal error: The miniport has detected an internal error
(I)8000 - Miniport Halt flow (driver disable)
(E)5006 Intel(R) Wi-Fi 6 AX200 160MHz : The version number is incorrect for this driver.
This system does NOT have UEFI enabled in BIOS and Windows is NOT configured with secure boot.
OS: Windows 10 Home, 64-bit build 18363
I thought this should be a simple plug & play operation, but I've now spent 5 hours troubleshooting it. Any help would be greatly appreciated.
n_scott_pearson
After making the changes that you made (which you should have done - and stuck with - long ago, just saying), I suggest that you try doing a clean reinstallation of the driver stack - and yes, include both Bluetooth and Wireless.
Hope this helps,
JoshIN818
It looks like it's not even secure boot related. I just went and disable secure boot, but left it uefi instead of back to csm as it was, and loaded back into windows, and wifi card still same issue. Went back into bios and switched uefi to csm, and wifi card works again once back in windows.
n_scott_pearson
Did you try doing the clean reinstall?
