Wireless
8846 Discussions
WiFi adapter gets disabled when plugging in Ethernet cable
a_k_bluered
My system is Windows 11 on a Dell Precision 5560 Notebook with an Intel WiFi 6 AX201 adapter.
The problem is that when I plug in an Ethernet cable, the WiFi adapter gets automatically disabled. The computer does have a BIOS setting "Wireless Radio Control" which advertises just that behavior, but the setting is already disabled. Also, the disabling of the WiFi adapter isn't immediate. I can re-enable the adapter in device manager and it'll "survive" a few seconds before it gets disabled again by who-knows-what. I've also seen mention in a Dell knowledge base article of the Intel Administrator Toolset that might allow configuration of that behavior. But the only installer that allows installing this seems to be for Windows 7/8.
Steven_Intel
Hello a_k_bluered,
In order to better assist you, please provide the following information:
  • Was this behavior not present before? If so, was there any hardware/driver/OS change before it started?
  • How are you re-enabling the Wi-Fi adapter in Device Manager?
  • Provide pictures/screenshots or a video showing the Wi-Fi being disabled once the Ethernet cable is connected.
Steven G.
a_k_bluered
Hi Steven
The behavior was like this from the beginning. I've had this laptop for 3 months.
When the wireless device gets disabled, the context menu entry in the device manager for "Disable device" changes to "Enable device". To enable the device in device manager I click "Enable device" in the context menu of the device. The adapter also shows as disabled in the network adapter options (i.e. in Windows 11 network and internet settings->advanced network settings->more network adapter options). I found that trying to reenable it from there has exactly the same behavior as from device manager (i.e. it switches back to disabled after 1 or 2 seconds).
Steven_Intel
Thank you for your response.
I would like to research more about this. In order to do so, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven_Intel
Steven G.
a_k_bluered
Hi
Please find attached the info file.
a_k_bluered
Also, it is interesting to note that this issue does not occur under Linux (both interfaces can be used simultaneously, packets can be forwarded between them, etc.). Hence, this probably indicates a Windows driver/configuration issue.
Steven_Intel
Please try a clean installation of the latest driver 22.160.0.4 (https://www.intel.com/content/www/us/en/download/19351/windows-10-and-windows-11-wi-fi-drivers-for-intel-wireless-adapters.html) and also the customized driver provided by Dell 22.160.0.3 (https://www.dell.com/support/home/en-us/product-support/product/precision-15-5560-laptop/drivers)
Please let me know of the outcome.
Steven G.
Steven_Intel
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
Steven_Intel
Hello a_k_bluered,
Since there is an option that mentions this behavior on the BIOS, our best recommendation is to check this setting with the device manufacturer (OEM) for further assistance.
OEM contact information: https://www.intel.com/content/www/us/en/support/contact-intel.html?tab=system-manufacturers
Steven G.
