Wireless
8710 Discussions
Wifi AX201 on Parrot OS
BugHunter
Bought a new laptop with configuration:
____________________________________________
CPU: 11th Gen Intel i7-1165G7 (8) @ 4.700GHz
Kernel: 5.14.0-9parrot1-amd64
OS: Parrot OS 5.0 (LTS) x86_64
Host: HP ProBook 450 G8 Notebook PC
My wifi ( Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi) is not working with internal Wifi card and working with an external adapter it is not damaged (works with windows 11) and I am stuck with this for 2 months.
OTHER QUESTIONS:
Is Bluetooth working? > Yes it is working fine.
Does Wifi stopped after any update? > No, It did'nt work since I installed linux.
TERMINAL OUTPUTS:
sudo modinfo iwlwifi
filename:       /lib/modules/5.14.0-9parrot1-amd64/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
author:         Intel Corporation <linuxwifi@intel.com>
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
and so many other files list
sudo dmesg | grep iwlwifi
Very long List
DeividA_Intel
Hello BugHunter,
1. Provide the Intel® System Support Utility for the Linux* Operating System for more details (it is possible):
2. Is this the original adapter that came pre-installed on your computer or did you change/install the adapter to this one?
3. Have you noticed any error codes related to the wireless adapter?
4. What is the brand and model name of your router?
5. Have you checked with the Parrot Support Team to confirm if there are driver and firmware for the Intel® Wi-Fi 6 AX201 (Gig+)?
Deivid A.
BugHunter
Hi DeividA_Intel,
There is a wifi card which was originally built in my PC.
no errors are shown to me
parrot team is saying they have a support since AX201 is a popular wifi card
DeividA_Intel
Hello BugHunter,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
DeividA_Intel
Hello BugHunter,
We have not heard back from you, so we will close this inquiry. If you need further assistance or if you have additional questions, please create a new thread and we will gladly assist you.
Deivid A.
BugHunter
Hi Deivid,
Sorry, I am responding to you too late.
My problem is still the same, I was hoping that an upgrade in the Linux kernel will help with my wifi issue, but after 5.14 now I am using 5.16 but still same problem.
I am revising my issue, you can look in the parrot community website HERE
Hope you will help to solve my problem.
