Wireless
8851 Discussions
Windows® 10 Wi-Fi Drivers for Intel® Wireless Adapters
okumura007
複数の問題があるとのことでインストールが出来ませんが、皆様もでしょうか?
https://downloadcenter.intel.com/download/29815
ログはこんな感じです。
何が問題かわかりません。
[3748:32B8][2020-09-02T21:55:28]i001: Burn v3.11.1.2318, Windows v10.0 (Build 18363: Service Pack 0), path: C:\WINDOWS\Temp\{47F04402-4197-4702-8D64-2F2D80095F1E}\.cr\WirelessSetup.exe
[3748:32B8][2020-09-02T21:55:28]i000: Initializing numeric variable 'ModifyScreenEnabled' to value '0'
[3748:32B8][2020-09-02T21:55:28]i009: Command Line: '-burn.clean.room=C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\WirelessSetup.exe -burn.filehandle.attached=692 -burn.filehandle.self=696'
[3748:32B8][2020-09-02T21:55:28]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\WirelessSetup.exe'
[3748:32B8][2020-09-02T21:55:28]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\'
[3748:32B8][2020-09-02T21:55:29]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529.log'
[3748:32B8][2020-09-02T21:55:29]i052: Condition 'VersionNT >= v10.0' evaluates to true.
[3748:32B8][2020-09-02T21:55:29]i000: Setting string variable 'WixBundleName' to value 'Intel® Software Installer'
[3748:32B8][2020-09-02T21:55:29]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[3748:32B8][2020-09-02T21:55:29]i000: Loading managed bootstrapper application.
[3748:32B8][2020-09-02T21:55:29]i000: Creating BA thread to run asynchronously.
[3748:0FF4][2020-09-02T21:55:29]i000: Entry point of WiX - Run method
[3748:0FF4][2020-09-02T21:55:29]i000: InstallAction = Install
[3748:0FF4][2020-09-02T21:55:29]i000: Current locale: ja-JP
[3748:0FF4][2020-09-02T21:55:29]i000: Setting string variable 'Documentation_DisplayName' to value '説明書'
[3748:0FF4][2020-09-02T21:55:29]i000: Setting string variable 'MinSupportedOsVersion' to value '10.0.16299.0'
[3748:0FF4][2020-09-02T21:55:29]i000: Setting string variable 'ProductName' to value 'インテル® PROSet/Wireless WiFi ソフトウェア'
[3748:0FF4][2020-09-02T21:55:29]i000: RebootRequired: Setting to False.
[3748:32B8][2020-09-02T21:55:29]i100: Detect begin, 4 packages
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectBegin: Installed=False, PackageCount=4, Result=None
[3748:32B8][2020-09-02T21:55:29]i000: Setting string variable 'NETFRAMEWORK45' to value '528040'
[3748:32B8][2020-09-02T21:55:29]i102: Detected related bundle: {4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, type: Upgrade, scope: PerMachine, version: 21.90.3.2, operation: MajorUpgrade
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectRelatedBundle: BundleTag=InstallUWD_SFX, Operation=MajorUpgrade, PerMachine=True, ProductCode={4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, RelationType=Upgrade, Result=None, Version=21.90.3.2
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageBegin: PackageId=NetFx462Web, Result=None
[3748:32B8][2020-09-02T21:55:29]i000: Setting numeric variable 'NetFx462Web_Install' to value 0
[3748:32B8][2020-09-02T21:55:29]i052: Condition 'NETFRAMEWORK45 >= 394802' evaluates to true.
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageComplete: PackageId=NetFx462Web, State=Present, Status=0
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageBegin: PackageId=Pre_Install, Result=None
[3748:32B8][2020-09-02T21:55:29]i000: Setting numeric variable 'Pre_Install_Install' to value 0
[3748:32B8][2020-09-02T21:55:29]i052: Condition 'WixBundleInstalled' evaluates to false.
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageComplete: PackageId=Pre_Install, State=Absent, Status=0
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageBegin: PackageId=WIFI_Driver, Result=None
[3748:32B8][2020-09-02T21:55:29]i000: Setting numeric variable 'WIFI_Driver_Install' to value 0
[3748:32B8][2020-09-02T21:55:29]i000: Setting numeric variable 'WIFI_Driver_Install' to value 1
[3748:32B8][2020-09-02T21:55:29]i052: Condition 'WixBundleInstalled AND WIFI_Driver_Installed' evaluates to false.
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageComplete: PackageId=WIFI_Driver, State=Absent, Status=0
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageBegin: PackageId=DocsManager, Result=None
[3748:32B8][2020-09-02T21:55:29]i000: Setting numeric variable 'DocsManager_Install' to value 0
[3748:32B8][2020-09-02T21:55:29]i103: Detected related package: {59C2C057-0051-48B0-8570-75E21B5BBAE1}, scope: PerMachine, version: 21.90.3.2, language: 0 operation: MajorUpgrade
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectPackageComplete: PackageId=DocsManager, State=Absent, Status=0
[3748:32B8][2020-09-02T21:55:29]i101: Detected package: NetFx462Web, state: Present, cached: None
[3748:32B8][2020-09-02T21:55:29]i101: Detected package: Pre_Install, state: Absent, cached: None
[3748:32B8][2020-09-02T21:55:29]i101: Detected package: WIFI_Driver, state: Absent, cached: None
[3748:32B8][2020-09-02T21:55:29]i101: Detected package: DocsManager, state: Absent, cached: Complete
[3748:32B8][2020-09-02T21:55:29]i000: OnBurnEvent_DetectComplete: Status=0
[3748:32B8][2020-09-02T21:55:29]i199: Detect complete, result: 0x0
[3748:0FF4][2020-09-02T21:55:32]i000: Apply - PlanAction=Install
[3748:32B8][2020-09-02T21:55:32]i200: Plan begin, 4 packages, action: Install
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanBegin: PackageCount=4, Result=None
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanRelatedBundle: BundleId={4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, Result=None, State=Absent
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageBegin: PackageId=NetFx462Web, Result=None, State=Present
[3748:32B8][2020-09-02T21:55:32]w321: Skipping dependency registration on package with no dependency providers: NetFx462Web
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageComplete: Execute=None, PackageId=NetFx462Web, Requested=None, Rollback=None, State=Present, Status=0
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageBegin: PackageId=Pre_Install, Result=None, State=Present
[3748:32B8][2020-09-02T21:55:32]i000: PlanPackage(Pre_Install, Present)
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'Pre_Install_InstallCommand' to value '-preinstall -s "C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\setup.xml" -b "C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\WirelessSetup.exe" -c "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -l "[WixBundleLog_Pre_Install]"'
[3748:32B8][2020-09-02T21:55:32]w321: Skipping dependency registration on package with no dependency providers: Pre_Install
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WixBundleLog_Pre_Install' to value 'C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_000_Pre_Install.log'
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WixBundleRollbackLog_Pre_Install' to value 'C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_000_Pre_Install_rollback.log'
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageComplete: Execute=Install, PackageId=Pre_Install, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[3748:32B8][2020-09-02T21:55:32]i052: Condition 'WIFI_Driver_Install' evaluates to true.
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageBegin: PackageId=WIFI_Driver, Result=None, State=Present
[3748:32B8][2020-09-02T21:55:32]i000: PlanPackage(WIFI_Driver, Present)
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WIFI_Driver_InstallCommand' to value '-i -l "[WixBundleLog_WIFI_Driver]" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"'
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WIFI_Driver_RepairCommand' to value '-r -l "[WixBundleLog_WIFI_Driver]" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"'
[3748:32B8][2020-09-02T21:55:32]w321: Skipping dependency registration on package with no dependency providers: WIFI_Driver
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WixBundleLog_WIFI_Driver' to value 'C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_001_WIFI_Driver.log'
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WixBundleRollbackLog_WIFI_Driver' to value 'C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_001_WIFI_Driver_rollback.log'
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageComplete: Execute=Install, PackageId=WIFI_Driver, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageBegin: PackageId=DocsManager, Result=None, State=Present
[3748:32B8][2020-09-02T21:55:32]i000: PlanPackage(DocsManager, Present)
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WixBundleRollbackLog_DocsManager' to value 'C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_002_DocsManager_rollback.log'
[3748:32B8][2020-09-02T21:55:32]i000: Setting string variable 'WixBundleLog_DocsManager' to value 'C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_002_DocsManager.log'
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanPackageComplete: Execute=Install, PackageId=DocsManager, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[3748:32B8][2020-09-02T21:55:32]i201: Planned package: NetFx462Web, state: Present, default requested: Present, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3748:32B8][2020-09-02T21:55:32]i201: Planned package: Pre_Install, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: None
[3748:32B8][2020-09-02T21:55:32]i201: Planned package: WIFI_Driver, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: None
[3748:32B8][2020-09-02T21:55:32]i201: Planned package: DocsManager, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3748:32B8][2020-09-02T21:55:32]i207: Planned related bundle: {4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_PlanComplete: Status=0
[3748:32B8][2020-09-02T21:55:32]i299: Plan complete, result: 0x0
[3748:32B8][2020-09-02T21:55:32]i300: Apply begin
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_ApplyBegin: Result=None
[3748:32B8][2020-09-02T21:55:32]i000: OnBurnEvent_Elevate
[3748:32B8][2020-09-02T21:55:32]i010: Launching elevated engine process.
[3748:32B8][2020-09-02T21:55:32]i011: Launched elevated engine process.
[3748:32B8][2020-09-02T21:55:33]i012: Connected to elevated engine.
[1150:1118][2020-09-02T21:55:33]i358: Pausing automatic updates.
[1150:1118][2020-09-02T21:55:33]i359: Paused automatic updates.
[1150:1118][2020-09-02T21:55:33]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, options: 0x7, disable resume: No
[1150:1118][2020-09-02T21:55:33]i000: Caching bundle from: 'C:\WINDOWS\Temp\{CCD1D571-F339-49FA-86AD-E316E03C2C8D}\.be\WirelessSetup.exe' to: 'C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\WirelessSetup.exe'
[1150:1118][2020-09-02T21:55:33]i320: Registering bundle dependency provider: {95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, version: 21.120.0.9
[1150:1118][2020-09-02T21:55:33]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, resume: Active, restart initiated: No, disable resume: No
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CachePackageBegin: CachePayloads=2, PackageCacheSize=60448, PackageId=Pre_Install, Result=None
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyBegin: PackageId=Pre_Install, PayloadId=Pre_Install, Result=None
[1150:0CA8][2020-09-02T21:55:33]i305: Verified acquired payload: Pre_Install at path: C:\ProgramData\Package Cache\.unverified\Pre_Install, moving to: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe.
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyComplete: PackageId=Pre_Install, PayloadId=Pre_Install, Result=None, Status=0
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyBegin: PackageId=Pre_Install, PayloadId=Pre_Install_CommonUtils, Result=None
[1150:0CA8][2020-09-02T21:55:33]i305: Verified acquired payload: Pre_Install_CommonUtils at path: C:\ProgramData\Package Cache\.unverified\Pre_Install_CommonUtils, moving to: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\CommonUtils.dll.
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyComplete: PackageId=Pre_Install, PayloadId=Pre_Install_CommonUtils, Result=None, Status=0
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CachePackageComplete: PackageId=Pre_Install, Result=None, Status=0
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CachePackageBegin: CachePayloads=20, PackageCacheSize=68797068, PackageId=WIFI_Driver, Result=None
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None
[1150:0CA8][2020-09-02T21:55:33]i305: Verified acquired payload: WIFI_Driver at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\PnPInstaller.exe.
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None, Status=0
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None
[1150:0CA8][2020-09-02T21:55:33]i305: Verified acquired payload: WIFI_Driver_CommonUtils at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_CommonUtils, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\CommonUtils.dll.
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None, Status=0
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None
[1150:0CA8][2020-09-02T21:55:33]i305: Verified acquired payload: WIFI_Driver_UWDBootstrapper_Common at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_UWDBootstrapper_Common, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\UWDBootstrapper_Common.dll.
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None, Status=0
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay04B7BA67540B0095BC73ED636D906451, Result=None
[1150:0CA8][2020-09-02T21:55:33]i305: Verified acquired payload: pay04B7BA67540B0095BC73ED636D906451 at path: C:\ProgramData\Package Cache\.unverified\pay04B7BA67540B0095BC73ED636D906451, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw08.dat.
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay04B7BA67540B0095BC73ED636D906451, Result=None, Status=0
[3748:1880][2020-09-02T21:55:33]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay0677D5889B430455CDDC6C4DC4F6A396, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay0677D5889B430455CDDC6C4DC4F6A396 at path: C:\ProgramData\Package Cache\.unverified\pay0677D5889B430455CDDC6C4DC4F6A396, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw10.dat.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay0677D5889B430455CDDC6C4DC4F6A396, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay2873CDA579D7950D3D4C17A07168A0A1, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay2873CDA579D7950D3D4C17A07168A0A1 at path: C:\ProgramData\Package Cache\.unverified\pay2873CDA579D7950D3D4C17A07168A0A1, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwtw04.INF.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay2873CDA579D7950D3D4C17A07168A0A1, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay35FB6D8E6884E94E7C225DA0DF71FC6C, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay35FB6D8E6884E94E7C225DA0DF71FC6C at path: C:\ProgramData\Package Cache\.unverified\pay35FB6D8E6884E94E7C225DA0DF71FC6C, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\netwtw04.cat.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay35FB6D8E6884E94E7C225DA0DF71FC6C, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay41063248EE3AA268FFA8E2FF1846D40B, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay41063248EE3AA268FFA8E2FF1846D40B at path: C:\ProgramData\Package Cache\.unverified\pay41063248EE3AA268FFA8E2FF1846D40B, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwtw06.INF.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay41063248EE3AA268FFA8E2FF1846D40B, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay48B48C90F826F1CD08C052D6BC7B64C9, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay48B48C90F826F1CD08C052D6BC7B64C9 at path: C:\ProgramData\Package Cache\.unverified\pay48B48C90F826F1CD08C052D6BC7B64C9, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\netwtw06.cat.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay48B48C90F826F1CD08C052D6BC7B64C9, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay6B815D643351DB1AFB6F93115C889C90, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay6B815D643351DB1AFB6F93115C889C90 at path: C:\ProgramData\Package Cache\.unverified\pay6B815D643351DB1AFB6F93115C889C90, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\netwtw08.cat.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay6B815D643351DB1AFB6F93115C889C90, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay7907904DCA3E6DD9FC85731FAA7AEF07, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay7907904DCA3E6DD9FC85731FAA7AEF07 at path: C:\ProgramData\Package Cache\.unverified\pay7907904DCA3E6DD9FC85731FAA7AEF07, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwtw08.INF.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay7907904DCA3E6DD9FC85731FAA7AEF07, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay870BBD8E7ACF5A74EDE956905E8A39E8, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay870BBD8E7ACF5A74EDE956905E8A39E8 at path: C:\ProgramData\Package Cache\.unverified\pay870BBD8E7ACF5A74EDE956905E8A39E8, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\IntelIhvRouter04.dll.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay870BBD8E7ACF5A74EDE956905E8A39E8, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay93075B326AFE73207A458E9CA00522EF, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay93075B326AFE73207A458E9CA00522EF at path: C:\ProgramData\Package Cache\.unverified\pay93075B326AFE73207A458E9CA00522EF, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw06.dat.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay93075B326AFE73207A458E9CA00522EF, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay93BFB38CFF519E685DCAD26B1DBE0D6F, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay93BFB38CFF519E685DCAD26B1DBE0D6F at path: C:\ProgramData\Package Cache\.unverified\pay93BFB38CFF519E685DCAD26B1DBE0D6F, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\IntelIhvRouter08.dll.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay93BFB38CFF519E685DCAD26B1DBE0D6F, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay9EC4EA65B2E0D4FD4F7807707F7A6701, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: pay9EC4EA65B2E0D4FD4F7807707F7A6701 at path: C:\ProgramData\Package Cache\.unverified\pay9EC4EA65B2E0D4FD4F7807707F7A6701, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw04.sys.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay9EC4EA65B2E0D4FD4F7807707F7A6701, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payABAF2730D0AEE61EDED9B6471BC3D2AA, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: payABAF2730D0AEE61EDED9B6471BC3D2AA at path: C:\ProgramData\Package Cache\.unverified\payABAF2730D0AEE61EDED9B6471BC3D2AA, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\IntelIhvRouter06.dll.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payABAF2730D0AEE61EDED9B6471BC3D2AA, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payC77241F7342B4675B951A188CD6C35F4, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: payC77241F7342B4675B951A188CD6C35F4 at path: C:\ProgramData\Package Cache\.unverified\payC77241F7342B4675B951A188CD6C35F4, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw08.sys.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payC77241F7342B4675B951A188CD6C35F4, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payCC67C7C4AD5780898726312FFFE0E65A, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: payCC67C7C4AD5780898726312FFFE0E65A at path: C:\ProgramData\Package Cache\.unverified\payCC67C7C4AD5780898726312FFFE0E65A, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw04.dat.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payCC67C7C4AD5780898726312FFFE0E65A, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payCF8E7198AFAAE35477E10ABFD1CBFD52, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: payCF8E7198AFAAE35477E10ABFD1CBFD52 at path: C:\ProgramData\Package Cache\.unverified\payCF8E7198AFAAE35477E10ABFD1CBFD52, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw10.sys.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payCF8E7198AFAAE35477E10ABFD1CBFD52, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payE9050D5128CF6EA54EC13FC76D88B30E, Result=None
[1150:0CA8][2020-09-02T21:55:34]i305: Verified acquired payload: payE9050D5128CF6EA54EC13FC76D88B30E at path: C:\ProgramData\Package Cache\.unverified\payE9050D5128CF6EA54EC13FC76D88B30E, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw06.sys.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payE9050D5128CF6EA54EC13FC76D88B30E, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CachePackageComplete: PackageId=WIFI_Driver, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CachePackageBegin: CachePayloads=2, PackageCacheSize=3714548, PackageId=DocsManager, Result=None
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=DocsManager, PayloadId=DocsManager, Result=None
[1150:0CA8][2020-09-02T21:55:34]i304: Verified existing payload: DocsManager at path: C:\ProgramData\Package Cache\{1BE823A6-43D8-4162-8D3B-1C6DBC923FED}v21.120.0.9\DocsManager.msi.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=DocsManager, PayloadId=DocsManager, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyBegin: PackageId=DocsManager, PayloadId=DocFiles, Result=None
[1150:0CA8][2020-09-02T21:55:34]i304: Verified existing payload: DocFiles at path: C:\ProgramData\Package Cache\{1BE823A6-43D8-4162-8D3B-1C6DBC923FED}v21.120.0.9\cab1.cab.
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CacheVerifyComplete: PackageId=DocsManager, PayloadId=DocFiles, Result=None, Status=0
[3748:1880][2020-09-02T21:55:34]i000: OnBurnEvent_CachePackageComplete: PackageId=DocsManager, Result=None, Status=0
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecuteBegin: PackageCount=4, Result=None
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecutePackageBegin: PackageId=Pre_Install, Result=None, ShouldExecute=True
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=0, PackageId=Pre_Install, ProgressPercentage=0, Result=None
[1150:1118][2020-09-02T21:55:34]i301: Applying execute package: Pre_Install, action: Install, path: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe, arguments: '"C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe" -preinstall -s "C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\setup.xml" -b "C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\WirelessSetup.exe" -c "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -l "C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_000_Pre_Install.log"'
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=12, PackageId=Pre_Install, ProgressPercentage=50, Result=None
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=25, PackageId=Pre_Install, ProgressPercentage=100, Result=None
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecutePackageComplete: PackageId=Pre_Install, Restart=None, Result=None, Status=0
[3748:32B8][2020-09-02T21:55:34]i319: Applied execute package: Pre_Install, result: 0x0, restart: None
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecutePackageBegin: PackageId=WIFI_Driver, Result=None, ShouldExecute=True
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=25, PackageId=WIFI_Driver, ProgressPercentage=0, Result=None
[1150:1118][2020-09-02T21:55:34]i301: Applying execute package: WIFI_Driver, action: Install, path: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\PnPInstaller.exe, arguments: '"C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\PnPInstaller.exe" -i -l "C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_001_WIFI_Driver.log" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"'
[3748:32B8][2020-09-02T21:55:34]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=37, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=37, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[1150:1118][2020-09-02T21:55:35]e000: Error 0x80070001: Process returned error: 0x1
[1150:1118][2020-09-02T21:55:35]e000: Error 0x80070001: Failed to execute EXE package.
[3748:32B8][2020-09-02T21:55:35]e000: Error 0x80070001: Failed to configure per-machine EXE package.
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecutePackageComplete: PackageId=WIFI_Driver, Restart=None, Result=None, Status=-2147024895
[3748:32B8][2020-09-02T21:55:35]i319: Applied execute package: WIFI_Driver, result: 0x80070001, restart: None
[3748:32B8][2020-09-02T21:55:35]e000: Error 0x80070001: Failed to execute EXE package.
[1150:1118][2020-09-02T21:55:35]i351: Removing cached package: WIFI_Driver, from path: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecutePackageBegin: PackageId=Pre_Install, Result=None, ShouldExecute=False
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=50, PackageId=Pre_Install, ProgressPercentage=100, Result=None
[1150:1118][2020-09-02T21:55:35]i301: Applying rollback package: Pre_Install, action: Uninstall, path: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe, arguments: '"C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe" -l "C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_000_Pre_Install.log"'
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=37, PackageId=Pre_Install, ProgressPercentage=50, Result=None
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=25, PackageId=Pre_Install, ProgressPercentage=0, Result=None
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecutePackageComplete: PackageId=Pre_Install, Restart=None, Result=None, Status=0
[3748:32B8][2020-09-02T21:55:35]i319: Applied rollback package: Pre_Install, result: 0x0, restart: None
[1150:1118][2020-09-02T21:55:35]i351: Removing cached package: Pre_Install, from path: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\
[3748:32B8][2020-09-02T21:55:35]i000: OnBurnEvent_ExecuteComplete: Status=-2147024895
[1150:1118][2020-09-02T21:55:35]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, resume: None, restart: None, disable resume: No
[1150:1118][2020-09-02T21:55:35]i330: Removed bundle dependency provider: {95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}
[1150:1118][2020-09-02T21:55:35]i352: Removing cached bundle: {95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, from path: C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\
[1150:1118][2020-09-02T21:55:36]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, resume: None, restart initiated: No, disable resume: No
[3748:32B8][2020-09-02T21:55:36]i000: OnBurnEvent_ApplyComplete: Restart=None, Result=None, Status=-2147024895
[3748:32B8][2020-09-02T21:55:36]i000: Setting ReturnCode to ERROR
[3748:32B8][2020-09-02T21:55:36]i399: Apply complete, result: 0x80070001, restart: None, ba requested restart: No
[3748:0FF4][2020-09-02T21:55:37]i000: LogFolderLink_RequestNavigate()
[3748:32B8][2020-09-02T21:55:40]i500: Shutting down, exit code: 0x643
[3748:32B8][2020-09-02T21:55:40]i000: OnBurnEvent_Shutdown: Result=None
[3748:32B8][2020-09-02T21:55:40]i410: Variable: CommonAppDataFolder = C:\ProgramData\
[3748:32B8][2020-09-02T21:55:40]i410: Variable: DocsManager_Install = 0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: Documentation_DisplayName = 説明書
[3748:32B8][2020-09-02T21:55:40]i410: Variable: MinSupportedOsVersion = 10.0.16299.0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: ModifyScreenEnabled = 0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: NETFRAMEWORK45 = 528040
[3748:32B8][2020-09-02T21:55:40]i410: Variable: NetFx462Web_Install = 0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: Pre_Install_Install = 0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: Pre_Install_InstallCommand = -preinstall -s "C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\setup.xml" -b "C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\WirelessSetup.exe" -c "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -l "C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_000_Pre_Install.log"
[3748:32B8][2020-09-02T21:55:40]i410: Variable: ProcessorArchitecture = 9
[3748:32B8][2020-09-02T21:55:40]i410: Variable: ProductName = インテル® PROSet/Wireless WiFi ソフトウェア
[3748:32B8][2020-09-02T21:55:40]i410: Variable: RebootPending = 0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: VersionNT = 10.0.0.0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WIFI_Driver_Install = 1
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WIFI_Driver_InstallCommand = -i -l "C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_001_WIFI_Driver.log" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WIFI_Driver_RepairCommand = -r -l "C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_001_WIFI_Driver.log" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleAction = 5
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleElevated = 1
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleInstalled = 0
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleLog = C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529.log
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleLog_DocsManager = C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_002_DocsManager.log
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleLog_Pre_Install = C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_000_Pre_Install.log
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleLog_WIFI_Driver = C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_001_WIFI_Driver.log
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleManufacturer = Intel Corporation
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleName = Intel® Software Installer
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleOriginalSource = C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\WirelessSetup.exe
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleOriginalSourceFolder = C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleProviderKey = {95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleRollbackLog_DocsManager = C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_002_DocsManager_rollback.log
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleRollbackLog_Pre_Install = C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_000_Pre_Install_rollback.log
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleRollbackLog_WIFI_Driver = C:\Users\NARA007\AppData\Local\Temp\Intel®_Software_Installer_20200902215529_001_WIFI_Driver_rollback.log
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleSourceProcessFolder = C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleSourceProcessPath = C:\WINDOWS\TEMP\0c4a2134-ffcf-4c13-ac7a-2088734071bb\content\WirelessSetup.exe
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleTag = InstallUWD_SFX
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleUILevel = 4
[3748:32B8][2020-09-02T21:55:40]i410: Variable: WixBundleVersion = 21.120.0.9
[3748:32B8][2020-09-02T21:55:40]i007: Exit code: 0x643, restarting: No
AlexPavloff
I've got the same issue. When I try to install/update drivers for my Wi-fi adaptor (Wi-Fi 6 AX200 160MHz), the systme says there's an error and it can't continue the installation. It says "Fix the problems". But how? What are these problems?
AlexPavloff
Here's that error:
[30F4:14D4][2020-09-03T02:33:42]i001: Burn v3.11.1.2318, Windows v10.0 (Build 19041: Service Pack 0), path: C:\WINDOWS\Temp\{86FDC2B0-4A85-424B-90A8-59C959389425}\.cr\WirelessSetup.exe
[30F4:14D4][2020-09-03T02:33:42]i000: Initializing numeric variable 'ModifyScreenEnabled' to value '0'
[30F4:14D4][2020-09-03T02:33:42]i009: Command Line: '-burn.clean.room=C:\WINDOWS\TEMP\dc06ed0b-4f25-494a-956f-d3a1122a90f7\content\WirelessSetup.exe -burn.filehandle.attached=544 -burn.filehandle.self=532'
[30F4:14D4][2020-09-03T02:33:42]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\WINDOWS\TEMP\dc06ed0b-4f25-494a-956f-d3a1122a90f7\content\WirelessSetup.exe'
[30F4:14D4][2020-09-03T02:33:42]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\WINDOWS\TEMP\dc06ed0b-4f25-494a-956f-d3a1122a90f7\content\'
[30F4:14D4][2020-09-03T02:33:42]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342.log'
[30F4:14D4][2020-09-03T02:33:42]i052: Condition 'VersionNT >= v10.0' evaluates to true.
[30F4:14D4][2020-09-03T02:33:42]i000: Setting string variable 'WixBundleName' to value 'Intel® Software Installer'
[30F4:14D4][2020-09-03T02:33:42]i000: Setting string variable 'WixBundleManufacturer' to value 'Intel Corporation'
[30F4:14D4][2020-09-03T02:33:42]i000: Loading managed bootstrapper application.
[30F4:14D4][2020-09-03T02:33:42]i000: Creating BA thread to run asynchronously.
[30F4:3470][2020-09-03T02:33:42]i000: Entry point of WiX - Run method
[30F4:3470][2020-09-03T02:33:42]i000: InstallAction = Install
[30F4:3470][2020-09-03T02:33:42]i000: Current locale: ru-RU
[30F4:3470][2020-09-03T02:33:42]i000: Setting string variable 'Documentation_DisplayName' to value 'Документация'
[30F4:3470][2020-09-03T02:33:42]i000: Setting string variable 'MinSupportedOsVersion' to value '10.0.16299.0'
[30F4:3470][2020-09-03T02:33:42]i000: Setting string variable 'ProductName' to value 'ПО Intel® PROSet/Wireless WiFi'
[30F4:3470][2020-09-03T02:33:42]i000: RebootRequired: Setting to False.
[30F4:14D4][2020-09-03T02:33:43]i100: Detect begin, 4 packages
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectBegin: Installed=False, PackageCount=4, Result=None
[30F4:14D4][2020-09-03T02:33:43]i000: Setting string variable 'NETFRAMEWORK45' to value '528372'
[30F4:14D4][2020-09-03T02:33:43]i102: Detected related bundle: {4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, type: Upgrade, scope: PerMachine, version: 21.90.3.2, operation: MajorUpgrade
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectRelatedBundle: BundleTag=InstallUWD_SFX, Operation=MajorUpgrade, PerMachine=True, ProductCode={4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, RelationType=Upgrade, Result=None, Version=21.90.3.2
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageBegin: PackageId=NetFx462Web, Result=None
[30F4:14D4][2020-09-03T02:33:43]i000: Setting numeric variable 'NetFx462Web_Install' to value 0
[30F4:14D4][2020-09-03T02:33:43]i052: Condition 'NETFRAMEWORK45 >= 394802' evaluates to true.
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageComplete: PackageId=NetFx462Web, State=Present, Status=0
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageBegin: PackageId=Pre_Install, Result=None
[30F4:14D4][2020-09-03T02:33:43]i000: Setting numeric variable 'Pre_Install_Install' to value 0
[30F4:14D4][2020-09-03T02:33:43]i052: Condition 'WixBundleInstalled' evaluates to false.
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageComplete: PackageId=Pre_Install, State=Absent, Status=0
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageBegin: PackageId=WIFI_Driver, Result=None
[30F4:14D4][2020-09-03T02:33:43]i000: Setting numeric variable 'WIFI_Driver_Install' to value 0
[30F4:14D4][2020-09-03T02:33:43]i000: Setting numeric variable 'WIFI_Driver_Install' to value 1
[30F4:14D4][2020-09-03T02:33:43]i052: Condition 'WixBundleInstalled AND WIFI_Driver_Installed' evaluates to false.
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageComplete: PackageId=WIFI_Driver, State=Absent, Status=0
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageBegin: PackageId=DocsManager, Result=None
[30F4:14D4][2020-09-03T02:33:43]i000: Setting numeric variable 'DocsManager_Install' to value 0
[30F4:14D4][2020-09-03T02:33:43]i103: Detected related package: {59C2C057-0051-48B0-8570-75E21B5BBAE1}, scope: PerMachine, version: 21.90.3.2, language: 0 operation: MajorUpgrade
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectPackageComplete: PackageId=DocsManager, State=Absent, Status=0
[30F4:14D4][2020-09-03T02:33:43]i101: Detected package: NetFx462Web, state: Present, cached: None
[30F4:14D4][2020-09-03T02:33:43]i101: Detected package: Pre_Install, state: Absent, cached: None
[30F4:14D4][2020-09-03T02:33:43]i101: Detected package: WIFI_Driver, state: Absent, cached: None
[30F4:14D4][2020-09-03T02:33:43]i101: Detected package: DocsManager, state: Absent, cached: Complete
[30F4:14D4][2020-09-03T02:33:43]i000: OnBurnEvent_DetectComplete: Status=0
[30F4:14D4][2020-09-03T02:33:43]i199: Detect complete, result: 0x0
[30F4:3470][2020-09-03T02:33:47]i000: Apply - PlanAction=Install
[30F4:14D4][2020-09-03T02:33:47]i200: Plan begin, 4 packages, action: Install
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanBegin: PackageCount=4, Result=None
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanRelatedBundle: BundleId={4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, Result=None, State=Absent
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageBegin: PackageId=NetFx462Web, Result=None, State=Present
[30F4:14D4][2020-09-03T02:33:47]w321: Skipping dependency registration on package with no dependency providers: NetFx462Web
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageComplete: Execute=None, PackageId=NetFx462Web, Requested=None, Rollback=None, State=Present, Status=0
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageBegin: PackageId=Pre_Install, Result=None, State=Present
[30F4:14D4][2020-09-03T02:33:47]i000: PlanPackage(Pre_Install, Present)
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'Pre_Install_InstallCommand' to value '-preinstall -s "C:\WINDOWS\TEMP\dc06ed0b-4f25-494a-956f-d3a1122a90f7\content\setup.xml" -b "C:\WINDOWS\TEMP\dc06ed0b-4f25-494a-956f-d3a1122a90f7\content\WirelessSetup.exe" -c "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -l "[WixBundleLog_Pre_Install]"'
[30F4:14D4][2020-09-03T02:33:47]w321: Skipping dependency registration on package with no dependency providers: Pre_Install
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WixBundleLog_Pre_Install' to value 'C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_000_Pre_Install.log'
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WixBundleRollbackLog_Pre_Install' to value 'C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_000_Pre_Install_rollback.log'
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageComplete: Execute=Install, PackageId=Pre_Install, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[30F4:14D4][2020-09-03T02:33:47]i052: Condition 'WIFI_Driver_Install' evaluates to true.
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageBegin: PackageId=WIFI_Driver, Result=None, State=Present
[30F4:14D4][2020-09-03T02:33:47]i000: PlanPackage(WIFI_Driver, Present)
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WIFI_Driver_InstallCommand' to value '-i -l "[WixBundleLog_WIFI_Driver]" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"'
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WIFI_Driver_RepairCommand' to value '-r -l "[WixBundleLog_WIFI_Driver]" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"'
[30F4:14D4][2020-09-03T02:33:47]w321: Skipping dependency registration on package with no dependency providers: WIFI_Driver
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WixBundleLog_WIFI_Driver' to value 'C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_001_WIFI_Driver.log'
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WixBundleRollbackLog_WIFI_Driver' to value 'C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_001_WIFI_Driver_rollback.log'
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageComplete: Execute=Install, PackageId=WIFI_Driver, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageBegin: PackageId=DocsManager, Result=None, State=Present
[30F4:14D4][2020-09-03T02:33:47]i000: PlanPackage(DocsManager, Present)
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WixBundleRollbackLog_DocsManager' to value 'C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_002_DocsManager_rollback.log'
[30F4:14D4][2020-09-03T02:33:47]i000: Setting string variable 'WixBundleLog_DocsManager' to value 'C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_002_DocsManager.log'
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanPackageComplete: Execute=Install, PackageId=DocsManager, Requested=Present, Rollback=Uninstall, State=Absent, Status=0
[30F4:14D4][2020-09-03T02:33:47]i201: Planned package: NetFx462Web, state: Present, default requested: Present, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[30F4:14D4][2020-09-03T02:33:47]i201: Planned package: Pre_Install, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: None
[30F4:14D4][2020-09-03T02:33:47]i201: Planned package: WIFI_Driver, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: Yes, dependency: None
[30F4:14D4][2020-09-03T02:33:47]i201: Planned package: DocsManager, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[30F4:14D4][2020-09-03T02:33:47]i207: Planned related bundle: {4ac3b686-ca29-4a13-a973-06a4d4dd09e6}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_PlanComplete: Status=0
[30F4:14D4][2020-09-03T02:33:47]i299: Plan complete, result: 0x0
[30F4:14D4][2020-09-03T02:33:47]i300: Apply begin
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_ApplyBegin: Result=None
[30F4:14D4][2020-09-03T02:33:47]i000: OnBurnEvent_Elevate
[30F4:14D4][2020-09-03T02:33:47]i010: Launching elevated engine process.
[30F4:14D4][2020-09-03T02:33:47]i011: Launched elevated engine process.
[30F4:14D4][2020-09-03T02:33:47]i012: Connected to elevated engine.
[4894:3CE4][2020-09-03T02:33:47]i358: Pausing automatic updates.
[4894:3CE4][2020-09-03T02:33:47]i359: Paused automatic updates.
[4894:3CE4][2020-09-03T02:33:47]i370: Session begin, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, options: 0x7, disable resume: No
[4894:3CE4][2020-09-03T02:33:47]i000: Caching bundle from: 'C:\WINDOWS\Temp\{8FB23E8F-83D8-4CED-A103-376DAC2750C5}\.be\WirelessSetup.exe' to: 'C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\WirelessSetup.exe'
[4894:3CE4][2020-09-03T02:33:47]i320: Registering bundle dependency provider: {95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, version: 21.120.0.9
[4894:3CE4][2020-09-03T02:33:47]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, resume: Active, restart initiated: No, disable resume: No
[30F4:0CC0][2020-09-03T02:33:47]i000: OnBurnEvent_CachePackageBegin: CachePayloads=2, PackageCacheSize=60448, PackageId=Pre_Install, Result=None
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyBegin: PackageId=Pre_Install, PayloadId=Pre_Install, Result=None
[4894:3538][2020-09-03T02:33:48]i305: Verified acquired payload: Pre_Install at path: C:\ProgramData\Package Cache\.unverified\Pre_Install, moving to: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe.
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyComplete: PackageId=Pre_Install, PayloadId=Pre_Install, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyBegin: PackageId=Pre_Install, PayloadId=Pre_Install_CommonUtils, Result=None
[4894:3538][2020-09-03T02:33:48]i305: Verified acquired payload: Pre_Install_CommonUtils at path: C:\ProgramData\Package Cache\.unverified\Pre_Install_CommonUtils, moving to: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\CommonUtils.dll.
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyComplete: PackageId=Pre_Install, PayloadId=Pre_Install_CommonUtils, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CachePackageComplete: PackageId=Pre_Install, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CachePackageBegin: CachePayloads=20, PackageCacheSize=68797068, PackageId=WIFI_Driver, Result=None
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None
[4894:3538][2020-09-03T02:33:48]i305: Verified acquired payload: WIFI_Driver at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\PnPInstaller.exe.
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None
[4894:3538][2020-09-03T02:33:48]i305: Verified acquired payload: WIFI_Driver_CommonUtils at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_CommonUtils, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\CommonUtils.dll.
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_CommonUtils, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None
[4894:3538][2020-09-03T02:33:48]i305: Verified acquired payload: WIFI_Driver_UWDBootstrapper_Common at path: C:\ProgramData\Package Cache\.unverified\WIFI_Driver_UWDBootstrapper_Common, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\UWDBootstrapper_Common.dll.
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=WIFI_Driver_UWDBootstrapper_Common, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay04B7BA67540B0095BC73ED636D906451, Result=None
[4894:3538][2020-09-03T02:33:48]i305: Verified acquired payload: pay04B7BA67540B0095BC73ED636D906451 at path: C:\ProgramData\Package Cache\.unverified\pay04B7BA67540B0095BC73ED636D906451, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw08.dat.
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay04B7BA67540B0095BC73ED636D906451, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:48]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay0677D5889B430455CDDC6C4DC4F6A396, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay0677D5889B430455CDDC6C4DC4F6A396 at path: C:\ProgramData\Package Cache\.unverified\pay0677D5889B430455CDDC6C4DC4F6A396, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw10.dat.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay0677D5889B430455CDDC6C4DC4F6A396, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay2873CDA579D7950D3D4C17A07168A0A1, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay2873CDA579D7950D3D4C17A07168A0A1 at path: C:\ProgramData\Package Cache\.unverified\pay2873CDA579D7950D3D4C17A07168A0A1, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwtw04.INF.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay2873CDA579D7950D3D4C17A07168A0A1, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay35FB6D8E6884E94E7C225DA0DF71FC6C, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay35FB6D8E6884E94E7C225DA0DF71FC6C at path: C:\ProgramData\Package Cache\.unverified\pay35FB6D8E6884E94E7C225DA0DF71FC6C, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\netwtw04.cat.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay35FB6D8E6884E94E7C225DA0DF71FC6C, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay41063248EE3AA268FFA8E2FF1846D40B, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay41063248EE3AA268FFA8E2FF1846D40B at path: C:\ProgramData\Package Cache\.unverified\pay41063248EE3AA268FFA8E2FF1846D40B, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwtw06.INF.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay41063248EE3AA268FFA8E2FF1846D40B, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay48B48C90F826F1CD08C052D6BC7B64C9, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay48B48C90F826F1CD08C052D6BC7B64C9 at path: C:\ProgramData\Package Cache\.unverified\pay48B48C90F826F1CD08C052D6BC7B64C9, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\netwtw06.cat.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay48B48C90F826F1CD08C052D6BC7B64C9, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay6B815D643351DB1AFB6F93115C889C90, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay6B815D643351DB1AFB6F93115C889C90 at path: C:\ProgramData\Package Cache\.unverified\pay6B815D643351DB1AFB6F93115C889C90, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\netwtw08.cat.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay6B815D643351DB1AFB6F93115C889C90, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay7907904DCA3E6DD9FC85731FAA7AEF07, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay7907904DCA3E6DD9FC85731FAA7AEF07 at path: C:\ProgramData\Package Cache\.unverified\pay7907904DCA3E6DD9FC85731FAA7AEF07, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwtw08.INF.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay7907904DCA3E6DD9FC85731FAA7AEF07, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay870BBD8E7ACF5A74EDE956905E8A39E8, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay870BBD8E7ACF5A74EDE956905E8A39E8 at path: C:\ProgramData\Package Cache\.unverified\pay870BBD8E7ACF5A74EDE956905E8A39E8, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\IntelIhvRouter04.dll.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay870BBD8E7ACF5A74EDE956905E8A39E8, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay93075B326AFE73207A458E9CA00522EF, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay93075B326AFE73207A458E9CA00522EF at path: C:\ProgramData\Package Cache\.unverified\pay93075B326AFE73207A458E9CA00522EF, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw06.dat.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay93075B326AFE73207A458E9CA00522EF, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay93BFB38CFF519E685DCAD26B1DBE0D6F, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay93BFB38CFF519E685DCAD26B1DBE0D6F at path: C:\ProgramData\Package Cache\.unverified\pay93BFB38CFF519E685DCAD26B1DBE0D6F, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\IntelIhvRouter08.dll.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay93BFB38CFF519E685DCAD26B1DBE0D6F, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=pay9EC4EA65B2E0D4FD4F7807707F7A6701, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: pay9EC4EA65B2E0D4FD4F7807707F7A6701 at path: C:\ProgramData\Package Cache\.unverified\pay9EC4EA65B2E0D4FD4F7807707F7A6701, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw04.sys.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=pay9EC4EA65B2E0D4FD4F7807707F7A6701, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payABAF2730D0AEE61EDED9B6471BC3D2AA, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: payABAF2730D0AEE61EDED9B6471BC3D2AA at path: C:\ProgramData\Package Cache\.unverified\payABAF2730D0AEE61EDED9B6471BC3D2AA, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\IntelIhvRouter06.dll.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payABAF2730D0AEE61EDED9B6471BC3D2AA, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payC77241F7342B4675B951A188CD6C35F4, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: payC77241F7342B4675B951A188CD6C35F4 at path: C:\ProgramData\Package Cache\.unverified\payC77241F7342B4675B951A188CD6C35F4, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw08.sys.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payC77241F7342B4675B951A188CD6C35F4, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payCC67C7C4AD5780898726312FFFE0E65A, Result=None
[4894:3538][2020-09-03T02:33:49]i305: Verified acquired payload: payCC67C7C4AD5780898726312FFFE0E65A at path: C:\ProgramData\Package Cache\.unverified\payCC67C7C4AD5780898726312FFFE0E65A, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\Netwfw04.dat.
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payCC67C7C4AD5780898726312FFFE0E65A, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:49]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payCF8E7198AFAAE35477E10ABFD1CBFD52, Result=None
[4894:3538][2020-09-03T02:33:50]i305: Verified acquired payload: payCF8E7198AFAAE35477E10ABFD1CBFD52 at path: C:\ProgramData\Package Cache\.unverified\payCF8E7198AFAAE35477E10ABFD1CBFD52, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw10.sys.
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payCF8E7198AFAAE35477E10ABFD1CBFD52, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CacheVerifyBegin: PackageId=WIFI_Driver, PayloadId=payE9050D5128CF6EA54EC13FC76D88B30E, Result=None
[4894:3538][2020-09-03T02:33:50]i305: Verified acquired payload: payE9050D5128CF6EA54EC13FC76D88B30E at path: C:\ProgramData\Package Cache\.unverified\payE9050D5128CF6EA54EC13FC76D88B30E, moving to: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\Components\WiFiDriver\NETwtw06.sys.
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CacheVerifyComplete: PackageId=WIFI_Driver, PayloadId=payE9050D5128CF6EA54EC13FC76D88B30E, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CachePackageComplete: PackageId=WIFI_Driver, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CachePackageBegin: CachePayloads=2, PackageCacheSize=3714548, PackageId=DocsManager, Result=None
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CacheVerifyBegin: PackageId=DocsManager, PayloadId=DocsManager, Result=None
[4894:3538][2020-09-03T02:33:50]i304: Verified existing payload: DocsManager at path: C:\ProgramData\Package Cache\{1BE823A6-43D8-4162-8D3B-1C6DBC923FED}v21.120.0.9\DocsManager.msi.
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CacheVerifyComplete: PackageId=DocsManager, PayloadId=DocsManager, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CacheVerifyBegin: PackageId=DocsManager, PayloadId=DocFiles, Result=None
[4894:3538][2020-09-03T02:33:50]i304: Verified existing payload: DocFiles at path: C:\ProgramData\Package Cache\{1BE823A6-43D8-4162-8D3B-1C6DBC923FED}v21.120.0.9\cab1.cab.
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CacheVerifyComplete: PackageId=DocsManager, PayloadId=DocFiles, Result=None, Status=0
[30F4:0CC0][2020-09-03T02:33:50]i000: OnBurnEvent_CachePackageComplete: PackageId=DocsManager, Result=None, Status=0
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecuteBegin: PackageCount=4, Result=None
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecutePackageBegin: PackageId=Pre_Install, Result=None, ShouldExecute=True
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=0, PackageId=Pre_Install, ProgressPercentage=0, Result=None
[4894:3CE4][2020-09-03T02:33:50]i301: Applying execute package: Pre_Install, action: Install, path: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe, arguments: '"C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe" -preinstall -s "C:\WINDOWS\TEMP\dc06ed0b-4f25-494a-956f-d3a1122a90f7\content\setup.xml" -b "C:\WINDOWS\TEMP\dc06ed0b-4f25-494a-956f-d3a1122a90f7\content\WirelessSetup.exe" -c "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -l "C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_000_Pre_Install.log"'
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=12, PackageId=Pre_Install, ProgressPercentage=50, Result=None
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=25, PackageId=Pre_Install, ProgressPercentage=100, Result=None
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecutePackageComplete: PackageId=Pre_Install, Restart=None, Result=None, Status=0
[30F4:14D4][2020-09-03T02:33:50]i319: Applied execute package: Pre_Install, result: 0x0, restart: None
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecutePackageBegin: PackageId=WIFI_Driver, Result=None, ShouldExecute=True
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=25, PackageId=WIFI_Driver, ProgressPercentage=0, Result=None
[4894:3CE4][2020-09-03T02:33:50]i301: Applying execute package: WIFI_Driver, action: Install, path: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\PnPInstaller.exe, arguments: '"C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\PnPInstaller.exe" -i -l "C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_001_WIFI_Driver.log" -ic "C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\InstalledInfs.xml" -pi "WIFI_Driver" -f "'Components\WiFiDriver\Netwtw04.INF','Components\WiFiDriver\Netwtw06.INF','Components\WiFiDriver\Netwtw08.INF'"'
[30F4:14D4][2020-09-03T02:33:50]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=37, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=37, PackageId=WIFI_Driver, ProgressPercentage=50, Result=None
[4894:3CE4][2020-09-03T02:33:51]e000: Error 0x80070001: Process returned error: 0x1
[4894:3CE4][2020-09-03T02:33:51]e000: Error 0x80070001: Failed to execute EXE package.
[30F4:14D4][2020-09-03T02:33:51]e000: Error 0x80070001: Failed to configure per-machine EXE package.
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecutePackageComplete: PackageId=WIFI_Driver, Restart=None, Result=None, Status=-2147024895
[30F4:14D4][2020-09-03T02:33:51]i319: Applied execute package: WIFI_Driver, result: 0x80070001, restart: None
[30F4:14D4][2020-09-03T02:33:51]e000: Error 0x80070001: Failed to execute EXE package.
[4894:3CE4][2020-09-03T02:33:51]i351: Removing cached package: WIFI_Driver, from path: C:\ProgramData\Package Cache\08F41331B885503AAA34CA2755572560E18BA731\
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecutePackageBegin: PackageId=Pre_Install, Result=None, ShouldExecute=False
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=50, PackageId=Pre_Install, ProgressPercentage=100, Result=None
[4894:3CE4][2020-09-03T02:33:51]i301: Applying rollback package: Pre_Install, action: Uninstall, path: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe, arguments: '"C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\BootstrapperUtilityApp.exe" -l "C:\Users\Alessio\AppData\Local\Temp\Intel®_Software_Installer_20200903023342_000_Pre_Install.log"'
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=37, PackageId=Pre_Install, ProgressPercentage=50, Result=None
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecuteProgress: OverallPercentage=25, PackageId=Pre_Install, ProgressPercentage=0, Result=None
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecutePackageComplete: PackageId=Pre_Install, Restart=None, Result=None, Status=0
[30F4:14D4][2020-09-03T02:33:51]i319: Applied rollback package: Pre_Install, result: 0x0, restart: None
[4894:3CE4][2020-09-03T02:33:51]i351: Removing cached package: Pre_Install, from path: C:\ProgramData\Package Cache\08320F53B95CD63F945669221A654C9FBD13D817\
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ExecuteComplete: Status=-2147024895
[4894:3CE4][2020-09-03T02:33:51]i372: Session end, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, resume: None, restart: None, disable resume: No
[4894:3CE4][2020-09-03T02:33:51]i330: Removed bundle dependency provider: {95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}
[4894:3CE4][2020-09-03T02:33:51]i352: Removing cached bundle: {95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, from path: C:\ProgramData\Package Cache\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}\
[4894:3CE4][2020-09-03T02:33:51]i371: Updating session, registration key: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{95b1ecaf-4ad1-41f6-95b8-123162c5e0b8}, resume: None, restart initiated: No, disable resume: No
[30F4:14D4][2020-09-03T02:33:51]i000: OnBurnEvent_ApplyComplete: Restart=None, Result=None, Status=-2147024895
[30F4:14D4][2020-09-03T02:33:51]i000: Setting ReturnCode to ERROR
[30F4:14D4][2020-09-03T02:33:51]i399: Apply complete, result: 0x80070001, restart: None, ba requested restart: No
[30F4:3470][2020-09-03T02:33:57]i000: LogFolderLink_RequestNavigate()
johnMinelli
Same here. Waiting for a solution
Alberto_Sykes
okumura007, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
In order for us to provide the most accurate assistance, we just wanted to confirm a few details about your system:
What is the model of the Intel® Wireless card?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is this a new computer?
When did the issue start?
Did you make any recent hardware/software changes?
The wireless card, did you purchased it separately or did it came installed in the computer?
Which Windows* version are you using?
When you said you can't install, do you mean the Wireless driver or the Wireless card?
AlexPavloff, johnMinelli, Thank you for posting in the Intel® Communities Support.
Please submit your inquiry on a new thread, the reason for this is that every scenario is different even if the same product is being used, so for us to better assist you and in order to try to fix the problem, please submit a new thread:
https://communities.intel.com/community/tech
Let me apologize for any inconvenience.
Albert R.
A Contingent Worker at Intel
kaiserfernando
Good evening, I also confirm I have problems installing the new intel drivers 21.120.0.9 for AX200 wireless card, and also on nootebok ...
Alberto_Sykes
Hello okumura007, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
kaiserfernando, Thank you for posting in the Intel® Communities Support.
Albert R.
Alberto_Sykes
Hello okumura007, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
