Wireless
8667 Discussions
Windows® 11 Wi-Fi Drivers for Intel® Wireless Adapters (Installation Failed), WiFi-22.250.1
RMForlenza
I am attempting to install Windows 10 and Windows 11 Wi-Fi Drivers for Intel Wireless Adapters (WiFi-22.250.1-Driver64-Win10-Win11.exe). I have attempted manually downloading and installing after using Intel Driver & Support Assistant.
Each attempt results in an error dialogue stating ...
One or more issues caused the setup to fail. Please fix the issues and then retry setup.
There is no additional detail provided and I have no way of determining what issues caused the setup to fail. Thus I have no idea what needs fixing so that I can successfully setup the drivers.
n_scott_pearson
Did you run it As-Administrator?
RMForlenza
Yes, I attempted running as administrator with the same results.
Jose_Intel
Hello @RMForlenza
Thank you for posting on the Intel️® communities.
What is the specific issue you were having before the installation?
In order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
Jose B.
RMForlenza
Intel Driver and Support Agent told me there was an updated driver
There was no issue occuring prior to the update attempt.
Jose_Intel
Hello RMForlenza
Thank you for your reply.
Please do not forget to attach the report from Intel® System Support Utility for Windows.
Jose B.
RMForlenza
Jose_Intel
Hello RMForlenza
Thank you for the report.
We noticed that there is a newer version of the wireless driver for your adapter. Please download the file from here: 22.250.1.2
Then, perform a Clean Installation:
a.              Go to Device Manager.
b.              Expand the Network Adapters category.
c.              Right-click your Intel Wireless Adapter and choose to uninstall it.
d.              Make sure to the option to Delete the driver software for this device is selected.
e.              Repeat steps A through D until the option to Delete the driver software for this device is greyed out.
f.               Locate the driver you downloaded and Right-click it, then select the option to Run as administrator.
We also noticed that Windows is not up to date, we recommend having the system updated. Please go to Start > Settings > Update & Security > Windows Update and select Check for updates.
Jose B.
RMForlenza
Same response.
Is there anyway to download the diver files for a manual load, non executable file?
I saw that suggestion in another thread but cannot locate the files.
Also, on multiple computers, I am not able to reply in Edge or Chrome. Any ideas on why? I have to reply in the forum on my phone.
RMForlenza
I found the non-executable files and was able to manually load the latest driver.
Raygust
Can you please provide the link for non executable file i am facing the same issue.
rida
rida
I've run the Intel System Support Utility, but it can't attach the report because my laptop isn't connected to the internet
Jose_Intel
Hello RMForlenza
I am glad to hear that you have found the files and installed the driver. Is it working as expected now?
Jose B.
RMForlenza
Yes, all seems to be working well and the properties on the driver reflect the latest release.
Jose_Intel
Hello RMForlenza
We are glad to know you found a solution, thank you for taking the time to confirm it, and hopefully, it may help other community members experiencing similar behavior. Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Jose B.
