Wireless
8654 Discussions
Windows Server 2022 driver for Killer E3100G
abramesd
I have an ASROCK x670e Taichi Carrara motherboard with an AMD Ryzen 9 7950X3D processor.  The motherboard has the Intel Killer E3100G integrated into the motherboard
When I tried to install the Killer drivers for the LAN and WLAN adapters I get a message that the drivers don't support Windows Server 2022.  I tried to find Windows Server 2022 drivers on the Intel website but no luck.
Are there drivers for Windows Server 2022 for the Killer LAN and WLAN components?  If not, is there any suggestion to enable support for the Killer LAN and WLAN on Windows Server 2022?
David
AlfredoS_Intel
Hi Abramesd,
We know the difficulty of not having drivers for an Operating system that you are running. We value the helpful and timely resolution of your issue, and this could be the driver that you are looking for, https://www.intel.com/content/www/us/en/download/706171/intel-network-adapter-driver-for-windows-server-2022.html.
Please let us know if this driver addressed your concern.
Alfred S
AlfredoS_Intel
Hi Abramesd,
We are just following up.
It looks like you need more time to carry out the recommendations that we have provided.
Alfred S
abramesd
The driver you provided the link to did install.  It says there is no Intel device on my PC so I guess I'll just have to look else where for a solution or maybe revisit my plan and do something else.
AlfredoS_Intel
Hi Abramesd,
We appreciate your update on the matter and for considering trying our suggestions.
It is odd that you got the error message that you stated, when you ran the installer. Usually, if you experienced this the Killer networking components on your board maybe heavily customized by the motherboard manufacturer and that is the reason why our installer did not find any valid component for a driver update.
Please reach out to your motherboard manufacturer to ask if they have Windows Server 2022 validated drivers for the Killer networking hardware on your board.
Alfred S
AlfredoS_Intel
Hi Abramesd,
With that said, I will still check if there are any other workarounds for your concern.
Alfred S
AlfredoS_Intel
Hi Abramesd,
Thank you for your patience in waiting for an update.
We hope that the motherboard manufacturer is already assisting you in looking for a workaround for the issue.
As I have promised, I look for other workarounds for the issue that you are having and you may try to download and install version 28.0, since when I read the user guide for ethernet adapters, RSS was remove on later versions after 28.0.
Should you face the same problem, please continue to reach out to the system manufacturer, to check if your system is compatible with Windows Server 2022.
Alfred S
