Wireless
8695 Discussions
Wireless-AC 9560 160Mhz Code10
MarkM2
I have been struggling with the following issue for almost a year (I forgot the exacts dates) now. I come to the conclusion that maybe here I will find answers.
The problem started when wifi and bluetooth stopped working. Cheked device manager and it showed error Code 10. I dug into solutions, I have tried multiple drivers, clean windows installs (win 10 and 11 as well, currently on 11), BIOS updates, BIOS lock/unlock of wireless chip. All of these worked for a brief period of time, sometimes I managed to get the adapter running and I could use the built in WIFI and Bluetooth, but after each restart they failed again and Code 10 appeared. I would not think that this is a hardware issue as it sometimes works (5% of the time, 95% of the time it does not).
Specs:
Asus Vivobook S330FN
Processor: Intel Core i5-8265U
Memory: 8GB LPDDR3 2133 MHz
Graphics : 2GB NVIDIA GeForce MX150 GDDR5
Storage: 512GB M.2 NVMe™ PCIe® 3.0 SSD
Device manager:
Events: Error#1
Device PCI\VEN_8086&DEV_9DF0&SUBSYS_00348086&REV_30\3&11583659&0&A3 had a problem starting.
Driver Name: oem64.inf
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Service: Netwtw08
Lower Filters:
Upper Filters: vwifibus
Problem: 0x15
Problem Status: 0x0
Error#2
Driver Name: oem13.inf
Service: Netwtw08
Lower Filters:
Problem: 0x0
Problem Status: 0xC00000E5
Thank you in advance,
Mark
Jean_Intel
Hello MarkM2,
As you have performed extensive troubleshooting steps and have not resolved your issue just yet. We would recommend contacting your original equipment manufacturer (OEM) for additional support, and they may have the option to perform a hardware test to discard this possibility.
Jean O.
Jean_Intel
Hello MarkM2,
I hope you are doing fine.
Jean O.
Jean_Intel
Hello MarkM2.
Jean O.
