Wireless
9036 Discussions
Wireless Network Will Not Connect Automatically On Boot
I have a Intel 5300 card on a Dell P05S Tablet, I created a Profile (which works on different models that use the 5300 card) for our internal network. The problem is that it will not automatically connect to that profile on boot, when I right click on the profile on the PROSET software on the taskbar and then select that Profile it will connect, but after a reboot it will not connect automatically. The software I am using is version 13.1.1.0 which is know a newer version came out but this version that we use is the the only one that is certified for use on our network. I also tried to create the profile from *scratch* and not import the profile, but same results.
pls refer to solution http://www.intel.com/support/wireless/wlan/sb/cs-006205.htm here, it covers problem initiating connection.
you can also try update/reinstall the driver, too.
