Wireless
9021 Discussions
ac9260 FCC test modes under linux
piotrtwardosz
Dear support,
I would like to access RF tests modes on the PCI card Intel AC9260. The system is ubuntu linux.
Following earlier posts, I did a system scan using "Intel System Support Utility for Linux"
How can I provide a control interface for FCC tests? Is there any special command line tool for it?
System details:
Processor:"Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz"
          Serial Number:"Default string"
          SMBIOS Version:"3.1.1"
          Sound Cards:"HDA-Intel - HDA Intel PCH"
          Sound Cards:"HDA Intel PCH at 0xa1410000 irq 137"
          System Manufacturer:"AAEON"
          System Model:"MIX-H310D1"
          System Type:"x64-based PC"
 *-network
       description: Wireless interface
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 29
       serial: 1a:1c:42:07:d4:65
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=iwlwifi driverversion=4.19.0-11-amd64 firmware=34.0.0 latency=0 link=no multicast=yes wireless=IEEE 802.11
       resources: irq:18 memory:a1100000-a1103fff
Jean_Intel
Hello @piotrtwardosz,
We understand you have opened an email case with us and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
Jean O.
