Wireless
8663 Discussions
bpusb.sys seems to call always null pointer address when shutdown.
南昭弥
Windows XP 32bit driver bpusb.sys (7.5.1007.26)seems to call always null pointer address when shutdown.
I always had BSoD and get Crash Dump when Windows Shutdown final faze.
CrashDump
SYMBOL_STACK_INDEX: 17
ae0e915a 5d pop ebp
SYMBOL_NAME: bpusb+315a
IMAGE_NAME: bpusb.sys
BUCKET_ID: WRONG_SYMBOLS
I disassembled it.
bpusb.sys
SUB_L00013140:
mov edi,edi
push ebp
mov ebp,esp
mov eax,[ebp+0Ch]
push eax
mov ecx,[ebp+08h]
push ecx
mov edx,[L0001E0C8]
push edx
call [L0001DB30] <- Crashed
pop ebp
retn 0008h
It is Intel Wimax Link 5050 Series Function Driver.
It seems Address 0001DB30 is alwasy zero.
I tried to change the following code with hand assemble.
Changed code
SUB_L00013140:
retn 0008h
I felt the BSoD is disappeared.
jbenavides
Hello blackwingcat,
Thank you for your collaboration to Intel Communities.
The options available for this issue are very limited. Please keep in mind that the Intel® WiMax Link 5050 Series is no longer supported, and also Windows* XP has reached end of support from Microsoft. So, it is not possible to receive any further updates or modifications to any existing software in this configuration.
You might try using the https://downloadcenter.intel.com/product/39351/Intel-WiMAX-WiFi-Link-5150 Downloads for Intel® WiMAX/WiFi Link 5150, however, we cannot guarantee that this will work or be able to solve this issue.
