Wireless
8716 Discussions
código de error 1073807364
YOSSET
GOOD MORNING, I HAVE A PROBLEM WITH THE INSTALLATION AND I INSTALLED MANUALLY. MY DOUBT IS WHETHER THE PROBLEM WILL BE RESOLVED IN THE NEXT UPDATE OR WILL I ALWAYS HAVE TO DO IT MANUALLY. ANY SOLUTION? I ALREADY TRIED TO UNISTALL THE DRIVER SUPPORT AND THE WIFI DRIVER ITSELF.
THANKS IN ADVANCE.
AlHill
Do not be afraid to release the CAPS LOCK.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[If you find any Intel driver you might need, download and save it now.]
