Wireless
8721 Discussions
cant unpack drivers
MLawr4
the new wix based , chip-set and or wifi /Lan drivers
Cant seem to extract them, from exe to msi or the like. -x /x /extract , -extract kinda irksome
older Intel Driver packs chipset.exe -x c:\temp\intell-chipset or wifi , bluetooth and golden,
of late what gives ?
For A time I could Just get the zip, a Set of Scripts to pop the exe/msi would be nice, or adding back the -x or extract would be swell.
PDQ Deploy or https://wsuspackagepublisher.codeplex.com/ Wsus Package Publisher - Home I can push more updates once boxes are up.
for Windows Deploys On a stick , IE deploying baseline drivers , via Windows Installer for all systems in Offices good.
I can force push the MSI at a latter time from the server. however no WiFi or lan cable connectivity kinda bad.
any odd storage drivers I also try to Integrate... ie add on sata cards etc.
ASouz7
Necrose99,
You may try the IT Admin files found in this link: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000017246.html IT Administrator Links for Intel® PROSet/Wireless let us know if this works for you.
ASouz7
Necrose99,
MLawr4
ok the links working again or could have been ESET Endpoint Security blocking links. or just the links for google were expired.
just need chip-set ones next etc and all good.
its working so I can bake it into images, https://www.ntlite.com/ https://www.ntlite.com/
