Wireless
8617 Discussions
how to enable MLO on be200 ?
LuccaRehen
I have Ubuntu 24.04.1 LTS and installed kernel 6.13.
I inserted ASUS PCE-BE92BT having Intel be200, and are able to associate wireless to a WiFi 7 GW with MLO enabled, however the connection itself is not using MLO,
How can I check if MLO ( and which MLO types) and other WiFi 7 features are enabled and which  can be configured ?
Below iw dev, uname, lsb_release , lshw :
$ iw dev
phy#0
Unnamed/non-netdev interface
wdev 0x2
addr a0:b3:39:9d:20:fc
type P2P-device
Interface wlp4s0f0
ifindex 4
wdev 0x1
addr a0:b3:39:9d:20:fb
ssid Partner_6C6DD7
type managed
channel 36 (5180 MHz), width: 80 MHz, center1: 5210 MHz
txpower 22.00 dBm
multicast TXQ:
qsz-byt qsz-pkt flows drops marks overlmt hashcol tx-bytes tx-packets
0 0 0 0 0 0 0 0 0
$ uname -a
Linux cplx1070 6.13.0-061300-generic #202501302155 SMP PREEMPT_DYNAMIC Sat Feb 8 09:06:55 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 24.04.1 LTS
Release: 24.04
Codename: noble
$ sudo lshw -- relevant part :
physical id: 1d
bus info: pci@0000:00:1d.0
version: f1
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:123 memory:f7100000-f71fffff
*-network
description: Ethernet interface
product: Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:04:00.0
logical name: wlp4s0f0
version: 1a
serial: a0:b3:39:9d:20:fb
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical
configuration: broadcast=yes driver=iwlwifi driverversion=6.13.0-061300-generic firmware=94.62990553.0 gl-c0-fm-c0-94.uc ip=192.168.1.126 latency=0 link=yes multicast=yes
resources: irq:16 memory:f7100000-f7103fff
Lucca
LuccaRehen
on https://downloadmirror.intel.com/842132/ReleaseNotes_WiFi_LinuxCore89.pdf
there are 3 FW Repositories listed.
Can you confirm the firmware I have is OK and no download/upgrade is needed. If so, can you provide instructions starting from one or all of these FW's ?
Best regards
Lucca
JeanetteC_Intel
Hello LuccaRehen,
I'll check on this query and I will post an update once it's available.
JeanetteC.
JeanetteC_Intel
Hello LuccaRehen,
Based on further checking and details you shared; this component is only supported on Windows OS.
If this involves self-integration, kindly check the regulatory information available at this link: Regulatory Information Regarding Wireless Hardware Installation or Upgrade
I highly recommend checking with OEM for the latest firmware version to install and/or confirm the supported OS or AP setting to enable it.
JeanetteC.
Intel Customer Support
