Wireless
8991 Discussions
intel 3165 bug
超黄
eject intel 3165 wifi ,What's the problem, how to solve.
Hello rock-huang,
We understand that you're being given the option to eject your Intel® Dual Band Wireless-AC 3165 in the Safely Remove Hardware tray icon.
In order to investigate, we would like the following information:
1. Is this a factory installed wireless adapter, or an upgrade part?
2. Did this happen after updating to the latest drivers, or making changes to your system?
3. If you choose to eject the adapter, does it become disabled or stop being detected in Device Manager?
4. Are you experiencing any additional issues?
5. Please share a report generated using the Intel® System Support Utility.
1. Download the latest https://downloadcenter.intel.com/download/25293 Intel® SSU
2. While connected to your WiFi network, run the scan for "everything."
3. Save and name the report.
We look forward to hearing back from you.
Carlos A.
超黄
This is the report file, how to don't pop up wifi icon appear
Hello rock-huang,
Please install the latest drivers, and let us know if this resolves the problem.
- Bluetooth®: https://downloadcenter.intel.com/download/27622 Intel® Wireless Bluetooth® for Windows® 10 Version: 20.40.
- Wi-Fi: https://downloadcenter.intel.com/download/27615 Intel® PROSet/Wireless Software and Drivers for Windows® 10 Version: 20.40.0
Carlos A.
超黄
Above values can be modified ?
Hello rock-huang,
Your wireless adapter should not be accessible through the "Devices and Printers" menu. You're also missing some tabs in the Device Manager adapter properties window (right).
Safe removal required should be "" by default.
- Are you using the drivers provided in our previous response?
- Is this an originally installed using your M.2 slot, or are you using a PCIe or USB adapter to install it in your computer?
Carlos A.
超黄
use WiFi_20.40.0_PROSet64_Win10 version
this is an originally installed using USB adapter to install
wireless adapter should not be accessible through the "Devices and Printers" menu.There are ways to fix this problem ?
Hello rock-huang,
If you're using an USB adapter, this is expected and cannot be changed. If using USB adapter, your system will recognize this as an USB device, which would explain why you can see those safe removal options.
If your wireless adapter is connected directly to your motherboard using an M.2 slot, then you may need to reinstall your operating system:
https://support.microsoft.com/en-us/help/12415/windows-10-recovery-options Recovery options in Windows® 10
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
Carlos A.
