Wireless
8871 Discussions
intel centrino ultimate n6300
KBol
i have an intel centrino ultimate n6300 in my intel nuc. when the router stops the signal for some reason the centrino does not connect to the router even though be cell phone does. the intel centrino utility does not find any network. what should i do?
jbenavides
Hello Override431,
We will need more information about the issue, and also would like to present some initial recommendations.
- Please let us know the model of NUC you have, also the Operating System and wireless driver version. Provide any additional information or testing you may have done. Does it happen when resuming from sleep?
- We noticed that the Intel® Centrino® Ultimate-N 6300 is not listed in the tested peripherals for NUC systems, so we would need the information of the system in order to determine if this is a relevant factor.
- Please obtain and install the most recent version of the NUC BIOS and also the Wireless adapter driver from https://downloadcenter.intel.com/ Intel Download Center.
jbenavides
Hello Override431,
We found that you posted some of the system information in a different forum:
NUC: BOXD54250WYK2 CORE I5-4250U
Wireless Adapter: intel centrino ultimate n6300
Operating System: windows 7 home 64 bit.
Please follow these steps as they may help in this situation:
- Download https://downloadcenter.intel.com/download/24652/Intel-PROSet-Wireless-Software-and-Drivers-for-Windows-7- Intel® PROSet/Wireless Software and Drivers for Windows 7*, version 17.14.0. File name: Wireless_17.14.0_s64.exe.
- Go to Windows Device Manager, Network Adapters, right click on the Intel® Centrino® Ultimate-N 6300, and select uninstall, make sure to mark the option "Delete the driver software for this device".
- Install the Driver 17.14.0 you downloaded before.
- Go to Device Manager again and open the properties of the wireless adapter, make sure to mark the option (check the box) "Allow the computer to turn off this device to save power".
If the issue persists, apply the configuration from the document: http://www.intel.com/support/wireless/sb/CS-030709.htm?wapkw=wifi+recommended+settings What are the Recommended Settings for 802.11n Connectivity?
KBol
thnsks allot!! i have the nuc like 6 months now and i dont know what to do. i will try what you suggest and report th results. Also i have downloaded the intel driver update utility. I want to say that even thought the utility downloads and installs most of the drivers it fails to install these two:
- Nuvoton infrared CIR driver. For some reason the driver the task manager shows is version 2.4.2013.711. I unistalled and then run the utility again but to no avail. the driver remains 2.4.2013.711
-Chipset: Intel chipset device software for intel nuc. the utility reports failed in installing that driver. What should i do?
Thnks in advance
jbenavides
Hello Override431,
Let us know if the issue persists after applying the previous recommendations.
Here is the link to the downloads page for your Intel® NUC Kit D54250WYK:
https://downloadcenter.intel.com/product/76977/Intel-NUC-Kit-D54250WYK https://downloadcenter.intel.com/product/76977/Intel-NUC-Kit-D54250WYK
In that link you will be able to obtain the Latest BIOS update 0035, that was recommended before.
Also, if you are having issues with the automatic installation of drivers using Intel® Driver Update Utility, you can manually download the individual installer in the downloads page.
If you have further questions or issues with the NUC itself (aside from the wireless issue), we advise you to post your question in the/community/tech/nuc Intel® NUC Support Community.
KBol
hello i did everything you told and also i read the recomended settings for my router and the centrino ultimate.
So i think i have the answer: When i read about roaming agressiveness it said below medium. So set it to medium-low. The connections were dorpping faster. So for some time i closed the wifi altogether, because i didnt have any connection at all. Today i set it to 1. lowest on roaming agressiveness and the wifi found again the network and it connected!!! even though before once it droped it never connected again!!
I want to ask something else though. Is intel centrino ultimate n6300 better than some other wifi cards that are also recomended by intel by being compatible with the nuc like the Intel Dual Band Wireless-N 7260 [7260.HMWBNWB.R]? Should i put that card inside the nuc (since it has bluetooth as well)?
Which card is better?
jbenavides
Hello Override431,
Thank you for the update. We are glad that the adapter is now reconnecting normally to the network.
Regarding your question about replacing the adapter, the Intel® Dual Band Wireless-N 7260 and Intel® Centrino® Ultimate-N 6300, Dual Band are similar in many ways. The main difference is the Bluetooth feature available in the 7260 as you already mentioned. Here is a comparison from our specification page so you can check the details:
http://ark.intel.com/compare/75440,59474 http://ark.intel.com/compare/75440,59474
The 6300 is a pretty good Wireless-N adapter and since it is now working fine in your system, you might not need to replace it. However, if you need Bluetooth connectivity in the computer, you may consider the Intel® Dual Band Wireless-N 7260, or other Intel wireless adapter.
ANiet1
Hello jonathan_intel,
Same issue here. I have a Lenovo Thinkpad X201 with the latest drivers installed. However, although the LAN is working fine, the Wifi is not working.
Here is a screenshot with more details:
jbenavides
Hello Alberto_
Make sure to apply the configuration from the following document:
If the issue persists, try the following actions and provide details about the issue as it is not clear if it is the same as the original post.
Do you get any message or error if you try to connect to the wireless connection shown in the screenshot?
Does it connect and eventually disconnects, like in the original issue?
If you unplug the wired connection and reboot the PC, are you able to connect?
Try connecting to other wireless networks.
Is this the original adapter that came with the computer, or was this a custom upgrade?
Please let us know the driver version shown in Device Manager, the Operating System version (including 32 or 64 bits). Also let us know the model number and firmware version of your router (access point).
DKurs
Hi Jonathan!
I was earlier used driver 14.3.0.6 and I hadn't had much problems with INTEL N6300 (maybe 1 or 2 switching off, but manually restarting this devices from Device Manager helped me )
Today I decided to use new driver, that you write about it ( 17.14.0.). And... 4h and my wifi connections are very stable!! (0, zero switching off)
But when I installed it I saw something strange. In my properties, of this card, it is written that I had install driver numeber: 15.15.0.1 from 2014-11-17.
It is correct?
jbenavides
Hello Daniel303,
The Intel® PROSet/Wireless Software 17.14.0 package contains drivers for different models of Intel® Wi-Fi Adapters, the version shown in the adapter properties of Device Manager will depend on the adapter model and the OS version. In your case, the driver 15.15.0.1 is the correct one for the Intel® Centrino® Ultimate-N 6300 and Windows 7*.
The complete list and details can be found in the document: http://www.intel.com/support/wireless/wlan/sb/CS-034315.htm?wapkw=wireless+driver+version Intel® PROSet/Wireless Software Driver Versions by Operating System
