Wireless
8781 Discussions
intel wifi 6 ax201 not showing up on first boot
fabivs
Good morning,
I just got this ax201, and it works fine, ish. The Bluetooth is always working, but the wifi never shows up on first boot, and I always have to reboot the pc to make it work.
I have reinstalled the drivers and followed other steps found online but nothing seems to help. Not sure if it can help, but my motherboard is ASRock A620M-HDV/M.2+.
Thank you
n_scott_pearson
This feels like a BIOS issue. Have you checked to see whether you are running the latest BIOS for your mobo? If not, upgrade and check the results again. If so, you may need to involve AsRock in this analysis.
Hope this helps,
fabivs
Hi Scott,
Thank you for your answer. I do have the latest BIOS version. I might get in touch with asrock anyway at this point, because I can't think of anything else.
Thank you,
Fabio
