Wireless
8995 Discussions
intel wireless ac 8265 linux
AKuzm7
Hello Intel.
I use 8265ngw in my laptop with Fedora 25 on board. And i have unstable work on ac diapason. As i see 802.11n working good. I get some more using http://wireless.kernel.org/en/users/Drivers/iwlwifi en:users:drivers:iwlwifi [Linux Wireless] kernel.org drivers and
$echo "options iwlmvm power_scheme=1" | sudo tee /etc/modprobe.d/iwlmvm.conf
$echo "options iwlwifi bt_coex_active=0 " | sudo tee /etc/modprobe.d/iwlwifi.conf
But Windows drivers work much better and faster. Please pay more attention to linux drivers.
*-network
description: Wireless interface
product: Wireless 8265 / 8275
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 50
serial: 34:13:e8:60:a8:47
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=4.10.12-200.fc25.x86_64 firmware=22.361476.0 ip=192.168.1.12 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:131 memory:e2200000-e2201fff
Hello 8cosmos,
We are continuously working to improve our wireless adapters and the way they work in different environments. In this case, we advise you to use the latest driver and firmware available from the https://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi Linux Wireless page you linked before.
Please keep in mind that driver development happens in the open-source Linux community. Development support is only available through the open-source community mailing lists. If you consider that the driver is not working properly, please submit your feedback using the support mailing list found in that webpage, or check with your http://www.intel.com/content/www/us/en/support/topics/OEMs.html Computer Manufacturer Support.
For more information about this topic, please review the following advisory: http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005511.html Linux* Support for Intel® Wireless Adapters.
Jonathan B.
AKuzm7
Hello. Thank you for answer. As i seen my solution working good on my HP ProBook 470 g3. Thank you for OEM links. I test some time on speedtest and it was even faster then windows drivers. (akmod-wl was removed also) But i detect 42MB/s speed limit i though this is because of router, but router accept 867Mbit by specification.
I wish you good business. Intel was always good as i remember
Hello 8cosmos,
We are glad to know that the issue has been resolved. Feel free to contact us if you have any additional questions.
Jonathan B.
