Wireless
8667 Discussions
supporting monitor mode and packet injection.
zando
does 'Intel(R) Wi-Fi 6 AX201 160MHz' support monitor mode and packet injection.
Alberto_R_Intel
zando, Thank you for posting in the Intel® Communities Support.
In reference to your question, based on the details shown in the link below, Monitor mode and package injection are not supported by Intel® wireless adapters:
https://www.intel.com/content/www/us/en/support/articles/000058933/wireless/intel-wireless-ac-products.html
Since the products supported on this page do not include the Intel® Wi-Fi 6 AX201 (Gig+) card, I will do further research to confirm those details and as soon as I get any updates, I will post all the details on this thread.
Albert R.
Alberto_R_Intel
Hello zando, I just received an update on this matter.
After reviewing the case we can confirm that Windows* Monitor mode and package injection are not supported on Intel® wireless adapters. This also applies to the promiscuous mode. EVen though there is no public documentation available about it, you can always the following command line that will return what is and what is not supported for your wireless card:
- netsh wlan show wirelesscapabilities
Linux does support monitor mode but depends on the Linux driver. The command line '# iw list' will return what is and what is not supported for his wireless card. In this case, it will be needed to check directly with the WiFi Linux community about setting up monitor mode or package injection on Linux:
https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
Albert R.
k4rt
i think it might work for monitor mode and injection its just the matte of installing the driver for realtek 802.11ac i am about to test it but before this it worked in monitor mode for me on kali linux
jbendes
Did you ever get this working? And if so, did it require kernel driver modification to do packet injection on the AX210? What packet injection rates were you able to achieve?
420
I am curious about the packet injection as well
Mack-Moham
Hi jbendes, I've recently been experimenting with packet injection on the AX210 as well (using scapy and libpcap). I've gathered some insights from my implementation attempts. Would you mind sharing your email so we could compare notes more directly?
