Wireless
8608 Discussions
wifi 6 ax 200 issues on Ubuntu 20.04
Realming_Grape
Good Day
Ive seen a number of posts relating to my question but none have resolved the issue i have been experiencing.
Wifi on this device is intermittent depending on my location. if i am in the office, it connects but keeps dropping to no connection, but at my home office, theres no connection at all. Just tries to connect and say "Connection not available"
I am using Ubuntu 20.04.
Kind regards
AndrewG_Intel
Hello Realming_Grape
Linux drivers are part of the upstream Linux* kernel. They're available through the regular channels, distributions, or the Linux* kernel archives >> http://www.kernel.org/.
We support use of the drivers only in the kernel version the driver was a part of. Please review the table in the following link for a list of supported devices by the iwlwifi driver as well for installation instructions:
https://www.intel.com/content/www/us/en/support/articles/000005511/network-and-i-o/wireless.html
Find more information about supported devices and firmware versions on the Intel Wi-Fi Linux community page*: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi
If the issue persits once you have installed the proper driver for the Kernel version that is supported, please provide the following information:
1- Is the Intel® Wi-Fi 6 AX200 the original wireless adapter that came pre-installed in your system or did you install/integrate it?
2- When did it start to happen? Did it work fine before? Were you able to have your wireless connection in a normal/expected performance before using Linux or any other operating system? Please provide details
3- Computer PC or Laptop brand and model: (if this is a custom PC built, please provide motherobard brand and model and BIOS version):
4- Kernel version:
5- Driver version used (you may provide the specific download link that you used):
6- Router/Accesss point brand and model (both used at the office and and at home):
7- Steps to replicate the behavior:
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
Realming_Grape
Hi Andrew,
Please see reply below in red
Yes, its the original device
this is the second time its started happening. i had to reload OS previously to get it resolved. it works for a bit then reverts back. I Have Windows OS aswell that works perfectly
HP Elitebook 830 G6
4- Kernel version:
[    0.000000] Linux version 5.4.0-48-generic (buildd@lcy01-amd64-010) (gcc version 9.3.0 (Ubuntu 9.3.0-10ubuntu2)) #52-Ubuntu SMP Thu Sep 10 10:58:49 UTC 2020 (Ubuntu 5.4.0-48.52-generic 5.4.60)
[    0.382965] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.629840] pps_core: LinuxPPS API ver. 1 registered
[    0.938015] Linux agpgart interface v0.103
[    1.032633] usb usb1: Manufacturer: Linux 5.4.0-48-generic xhci-hcd
[    1.035402] usb usb2: Manufacturer: Linux 5.4.0-48-generic xhci-hcd
[    1.038245] usb usb3: Manufacturer: Linux 5.4.0-48-generic xhci-hcd
[    1.039262] usb usb4: Manufacturer: Linux 5.4.0-48-generic xhci-hcd
[    3.034358] mc: Linux media interface: v0.10
[    3.035876] Intel(R) Wireless WiFi driver for Linux
[    3.041563] videodev: Linux video capture interface: v2.00
https://wireless.wiki.kernel.org/_media/en/users/drivers/iwlwifi/iwlwifi-cc-46.3cfab8da.0.tgz
TP Link AC1750 at home and HP MSM410 at the Office
Try to connect to WIFI
AndrewG_Intel
Thank you for your response and all the information provided.
Could you please try the following steps and provide us with the results?
1- Type in the following command to the terminal: # lspci​
Verify that the Intel® Wi-Fi 6 AX200 ​is identified. You should see something like "Network controller: Intel® Corporation AX200" or similar.
If it is not identified, then the system doesn't identify the Intel networidentifyk adapter and it would be needed to make sure it's properly integrated. You may need to request help from the system manufacturer. If the wireless adapter is properly identified, proceed with the next step.
2- Let's verify iwlwifi status:
2.1- Type in the following command to the terminal: # modinfo iwlwifi
Please provide us with the output. If there is no output, then the module isn’t installed and this is a distribution installation issue.
2.2- Type in: # lsmod | grep iwlwifi​ and share the output.
If the result is empty, the driver hasn't been loaded. Most likely due to a distribution issue.
2.3- To verify, please type: # dmesg | grep iwlwifi​ and share the output with us.
If the result is empty, the driver wasn’t initialized and this is a distribution issue.
3- Also, we noticed that the routers used do not support the ax standard but only n or ac standards. By any chance are you able to test with another router that is ax compatible?
Andrew G.
Realming_Grape
00:00.0 Host bridge: Intel Corporation Coffee Lake HOST and DRAM Controller (rev 0c)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (Whiskey Lake) (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0c)
00:12.0 Signal processing controller: Intel Corporation Cannon Point-LP Thermal Controller (rev 11)
00:14.0 USB controller: Intel Corporation Cannon Point-LP USB 3.1 xHCI Controller (rev 11)
00:14.2 RAM memory: Intel Corporation Cannon Point-LP Shared SRAM (rev 11)
00:15.0 Serial bus controller [0c80]: Intel Corporation Cannon Point-LP Serial IO I2C Controller #0 (rev 11)
00:15.1 Serial bus controller [0c80]: Intel Corporation Cannon Point-LP Serial IO I2C Controller #1 (rev 11)
00:16.0 Communication controller: Intel Corporation Cannon Point-LP MEI Controller #1 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #5 (rev f1)
00:1c.7 PCI bridge: Intel Corporation Cannon Point PCI Express Root Port #8 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Cannon Point-LP PCI Express Root Port #13 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Cannon Point-LP LPC Controller (rev 11)
00:1f.3 Multimedia audio controller: Intel Corporation Cannon Point-LP High Definition Audio Controller (rev 11)
00:1f.4 SMBus: Intel Corporation Cannon Point-LP SMBus Controller (rev 11)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Point-LP SPI Controller (rev 11)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (6) I219-V (rev 11)
01:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
02:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
02:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 2C 2018] (rev 06)
03:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 2C 2018] (rev 06)
39:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 2C 2018] (rev 06)
3a:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
3b:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
filename: /lib/modules/5.4.0-51-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license: GPL
author: Copyright(c) 2003- 2015 Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-ty-a0-gf-a0-50.ucode
firmware: iwlwifi-so-a0-gf-a0-50.ucode
firmware: iwlwifi-so-a0-hr-b0-50.ucode
firmware: iwlwifi-so-a0-jf-b0-50.ucode
firmware: iwlwifi-cc-a0-50.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-50.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-50.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-50.ucode
firmware: iwlwifi-Qu-b0-jf-b0-50.ucode
firmware: iwlwifi-Qu-c0-hr-b0-50.ucode
firmware: iwlwifi-QuQnj-a0-hr-a0-50.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-50.ucode
firmware: iwlwifi-QuQnj-f0-hr-a0-50.ucode
firmware: iwlwifi-Qu-a0-jf-b0-50.ucode
firmware: iwlwifi-Qu-a0-hr-a0-50.ucode
srcversion: B6DF401BA0F55B3F4BFBFC5
alias: pci:v00008086d00007AF0sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd00000510bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd00000310bc*sc*i*
alias: pci:v00008086d00007AF0sv*sd00000090bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000510bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000310bc*sc*i*
alias: pci:v00008086d00007A70sv*sd00000090bc*sc*i*
alias: pci:v00008086d00002725sv*sd000000B0bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000510bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000310bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000020bc*sc*i*
alias: pci:v00008086d00002725sv*sd00000090bc*sc*i*
alias: pci:v00008086d00002723sv*sd00004088bc*sc*i*
alias: pci:v00008086d00002723sv*sd00004080bc*sc*i*
alias: pci:v00008086d00002723sv*sd00002080bc*sc*i*
alias: pci:v00008086d00002723sv*sd00001654bc*sc*i*
alias: pci:v00008086d00002723sv*sd00001653bc*sc*i*
alias: pci:v00008086d00002723sv*sd0000008Cbc*sc*i*
alias: pci:v00008086d00002723sv*sd00000088bc*sc*i*
alias: pci:v00008086d00002723sv*sd00000084bc*sc*i*
alias: pci:v00008086d00002723sv*sd00000080bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00004244bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00004070bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00002074bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00001652bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00001651bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000A10bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000244bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd0000007Cbc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000078bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000074bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000070bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000044bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00004244bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00004070bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00002074bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00001652bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00001651bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000244bc*sc*i*
alias: pci:v00008086d000043F0sv*sd0000007Cbc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000078bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000074bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000070bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000044bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00004244bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00004070bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00002074bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00001652bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00001651bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000310bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000244bc*sc*i*
alias: pci:v00008086d000034F0sv*sd0000007Cbc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000078bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000074bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000070bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000044bc*sc*i*
alias: pci:v00008086d00002720sv*sd00004244bc*sc*i*
alias: pci:v00008086d00002720sv*sd00004070bc*sc*i*
alias: pci:v00008086d00002720sv*sd00002074bc*sc*i*
alias: pci:v00008086d00002720sv*sd00001652bc*sc*i*
alias: pci:v00008086d00002720sv*sd00001651bc*sc*i*
alias: pci:v00008086d00002720sv*sd00001080bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000310bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000244bc*sc*i*
alias: pci:v00008086d00002720sv*sd0000007Cbc*sc*i*
alias: pci:v00008086d00002720sv*sd00000078bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000074bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000070bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000044bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000040bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000000bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00004244bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00004070bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00002074bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00001652bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00001651bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000310bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000244bc*sc*i*
alias: pci:v00008086d000006F0sv*sd0000007Cbc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000078bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000074bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000070bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00004244bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00004070bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00002074bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00001652bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00001651bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000310bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000244bc*sc*i*
alias: pci:v00008086d000002F0sv*sd0000007Cbc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000078bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000074bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000070bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000030bc*sc*i*
alias: pci:v00008086d0000A370sv*sd000042A4bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00004234bc*sc*i*
alias: pci:v00008086d0000A370sv*sd000040A4bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00004034bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00004030bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00002034bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00002030bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00001552bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00001551bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00001210bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00001030bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00001010bc*sc*i*
alias: pci:v00008086d0000A370sv*sd000002A4bc*sc*i*
alias: pci:v00008086d0000A370sv*sd000002A0bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000264bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000260bc*sc*i*
alias: pci:v00008086d0000A370sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000238bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000234bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000230bc*sc*i*
alias: pci:v00008086d0000A370sv*sd000000A4bc*sc*i*
alias: pci:v00008086d0000A370sv*sd000000A0bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000064bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000060bc*sc*i*
alias: pci:v00008086d0000A370sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000038bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000034bc*sc*i*
alias: pci:v00008086d0000A370sv*sd00000030bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd000042A4bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00004234bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd000040A4bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00004034bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00004030bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00002034bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00002030bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00001552bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00001551bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00001030bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd000002A4bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd000002A0bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000264bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000260bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000238bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000234bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000230bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd000000A4bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd000000A0bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000064bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000060bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000038bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000034bc*sc*i*
alias: pci:v00008086d0000A0F0sv*sd00000030bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd000042A4bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00004234bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd000040A4bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00004034bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00004030bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00002A10bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00002034bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00002030bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00002010bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00001552bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00001551bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00001210bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00001030bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00001010bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000A10bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000710bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000610bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000510bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000410bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000310bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd000002A4bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd000002A0bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000264bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000260bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000238bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000234bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000230bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000210bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd000000A4bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd000000A0bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000064bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000060bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000038bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000034bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000030bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000010bc*sc*i*
alias: pci:v00008086d00009DF0sv*sd00000000bc*sc*i*
alias: pci:v00008086d000043F0sv*sd000042A4bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00004234bc*sc*i*
alias: pci:v00008086d000043F0sv*sd000040A4bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00004034bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00004030bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00002034bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00002030bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00001552bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00001551bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00001030bc*sc*i*
alias: pci:v00008086d000043F0sv*sd000002A4bc*sc*i*
alias: pci:v00008086d000043F0sv*sd000002A0bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000264bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000260bc*sc*i*
alias: pci:v00008086d000043F0sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000238bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000234bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000230bc*sc*i*
alias: pci:v00008086d000043F0sv*sd000000A4bc*sc*i*
alias: pci:v00008086d000043F0sv*sd000000A0bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000064bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000060bc*sc*i*
alias: pci:v00008086d000043F0sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000038bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000034bc*sc*i*
alias: pci:v00008086d000043F0sv*sd00000030bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd000042A4bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00004234bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd000040A4bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00004034bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00004030bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00002034bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00002030bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00001552bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00001551bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00001030bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd000002A4bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd000002A0bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000264bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000260bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000238bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000234bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000230bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd000000A4bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd000000A0bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000064bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000060bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000038bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000034bc*sc*i*
alias: pci:v00008086d00003DF0sv*sd00000030bc*sc*i*
alias: pci:v00008086d000034F0sv*sd000042A4bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00004234bc*sc*i*
alias: pci:v00008086d000034F0sv*sd000040A4bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00004034bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00004030bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00002034bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00002030bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00001552bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00001551bc*sc*i*
alias: pci:v00008086d000034F0sv*sd000002A4bc*sc*i*
alias: pci:v00008086d000034F0sv*sd000002A0bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000264bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000260bc*sc*i*
alias: pci:v00008086d000034F0sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000238bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000234bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000230bc*sc*i*
alias: pci:v00008086d000034F0sv*sd000000A4bc*sc*i*
alias: pci:v00008086d000034F0sv*sd000000A0bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000064bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000060bc*sc*i*
alias: pci:v00008086d000034F0sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000038bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000034bc*sc*i*
alias: pci:v00008086d000034F0sv*sd00000030bc*sc*i*
alias: pci:v00008086d000031DCsv*sd000042A4bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00004234bc*sc*i*
alias: pci:v00008086d000031DCsv*sd000040A4bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00004034bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00004030bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00002034bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00002030bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00001552bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00001551bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00001210bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00001030bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00001010bc*sc*i*
alias: pci:v00008086d000031DCsv*sd000002A4bc*sc*i*
alias: pci:v00008086d000031DCsv*sd000002A0bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000264bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000260bc*sc*i*
alias: pci:v00008086d000031DCsv*sd0000023Cbc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000238bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000234bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000230bc*sc*i*
alias: pci:v00008086d000031DCsv*sd000000A4bc*sc*i*
alias: pci:v00008086d000031DCsv*sd000000A0bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000064bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000060bc*sc*i*
alias: pci:v00008086d000031DCsv*sd0000003Cbc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000038bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000034bc*sc*i*
alias: pci:v00008086d000031DCsv*sd00000030bc*sc*i*
alias: pci:v00008086d000030DCsv*sd000042A4bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00004234bc*sc*i*
alias: pci:v00008086d000030DCsv*sd000040A4bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00004034bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00004030bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00002034bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00002030bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00001552bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00001551bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00001210bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00001030bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00001010bc*sc*i*
alias: pci:v00008086d000030DCsv*sd000002A4bc*sc*i*
alias: pci:v00008086d000030DCsv*sd000002A0bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000264bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000260bc*sc*i*
alias: pci:v00008086d000030DCsv*sd0000023Cbc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000238bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000234bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000230bc*sc*i*
alias: pci:v00008086d000030DCsv*sd000000A4bc*sc*i*
alias: pci:v00008086d000030DCsv*sd000000A0bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000064bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000060bc*sc*i*
alias: pci:v00008086d000030DCsv*sd0000003Cbc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000038bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000034bc*sc*i*
alias: pci:v00008086d000030DCsv*sd00000030bc*sc*i*
alias: pci:v00008086d00002720sv*sd000042A4bc*sc*i*
alias: pci:v00008086d00002720sv*sd00004234bc*sc*i*
alias: pci:v00008086d00002720sv*sd000040A4bc*sc*i*
alias: pci:v00008086d00002720sv*sd00004034bc*sc*i*
alias: pci:v00008086d00002720sv*sd00004030bc*sc*i*
alias: pci:v00008086d00002720sv*sd00002034bc*sc*i*
alias: pci:v00008086d00002720sv*sd00002030bc*sc*i*
alias: pci:v00008086d00002720sv*sd00001552bc*sc*i*
alias: pci:v00008086d00002720sv*sd00001551bc*sc*i*
alias: pci:v00008086d00002720sv*sd00001030bc*sc*i*
alias: pci:v00008086d00002720sv*sd000002A4bc*sc*i*
alias: pci:v00008086d00002720sv*sd000002A0bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000264bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000260bc*sc*i*
alias: pci:v00008086d00002720sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d00002720sv*sd00000238bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000234bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000230bc*sc*i*
alias: pci:v00008086d00002720sv*sd000000A4bc*sc*i*
alias: pci:v00008086d00002720sv*sd000000A0bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000064bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000060bc*sc*i*
alias: pci:v00008086d00002720sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d00002720sv*sd00000038bc*sc*i*
alias: pci:v00008086d00002720sv*sd00000034bc*sc*i*
alias: pci:v00008086d0000271Csv*sd00000214bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd00000214bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd00000210bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd00000014bc*sc*i*
alias: pci:v00008086d0000271Bsv*sd00000010bc*sc*i*
alias: pci:v00008086d00002526sv*sd0000E014bc*sc*i*
alias: pci:v00008086d00002526sv*sd0000E010bc*sc*i*
alias: pci:v00008086d00002526sv*sd0000A014bc*sc*i*
alias: pci:v00008086d00002526sv*sd00008010bc*sc*i*
alias: pci:v00008086d00002526sv*sd00008014bc*sc*i*
alias: pci:v00008086d00002526sv*sd00006014bc*sc*i*
alias: pci:v00008086d00002526sv*sd00006010bc*sc*i*
alias: pci:v00008086d00002526sv*sd000042A4bc*sc*i*
alias: pci:v00008086d00002526sv*sd00004234bc*sc*i*
alias: pci:v00008086d00002526sv*sd000040A4bc*sc*i*
alias: pci:v00008086d00002526sv*sd00004034bc*sc*i*
alias: pci:v00008086d00002526sv*sd00004030bc*sc*i*
alias: pci:v00008086d00002526sv*sd0000401Cbc*sc*i*
alias: pci:v00008086d00002526sv*sd00004018bc*sc*i*
alias: pci:v00008086d00002526sv*sd00004010bc*sc*i*
alias: pci:v00008086d00002526sv*sd00002034bc*sc*i*
alias: pci:v00008086d00002526sv*sd00002030bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001610bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001552bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001551bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001550bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001420bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001410bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001210bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001030bc*sc*i*
alias: pci:v00008086d00002526sv*sd00001010bc*sc*i*
alias: pci:v00008086d00002526sv*sd000002A4bc*sc*i*
alias: pci:v00008086d00002526sv*sd000002A0bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000264bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000260bc*sc*i*
alias: pci:v00008086d00002526sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d00002526sv*sd00000238bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000234bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000230bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000214bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000210bc*sc*i*
alias: pci:v00008086d00002526sv*sd000000A4bc*sc*i*
alias: pci:v00008086d00002526sv*sd000000A0bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000064bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000060bc*sc*i*
alias: pci:v00008086d00002526sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d00002526sv*sd00000038bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000034bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000030bc*sc*i*
alias: pci:v00008086d00002526sv*sd0000001Cbc*sc*i*
alias: pci:v00008086d00002526sv*sd00000018bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000014bc*sc*i*
alias: pci:v00008086d00002526sv*sd00000010bc*sc*i*
alias: pci:v00008086d000006F0sv*sd000042A4bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00004234bc*sc*i*
alias: pci:v00008086d000006F0sv*sd000040A4bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00004034bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00004030bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00002034bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00002030bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00001552bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00001551bc*sc*i*
alias: pci:v00008086d000006F0sv*sd000002A4bc*sc*i*
alias: pci:v00008086d000006F0sv*sd000002A0bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000264bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000260bc*sc*i*
alias: pci:v00008086d000006F0sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000238bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000234bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000230bc*sc*i*
alias: pci:v00008086d000006F0sv*sd000000A4bc*sc*i*
alias: pci:v00008086d000006F0sv*sd000000A0bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000064bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000060bc*sc*i*
alias: pci:v00008086d000006F0sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000038bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000034bc*sc*i*
alias: pci:v00008086d000006F0sv*sd00000030bc*sc*i*
alias: pci:v00008086d000002F0sv*sd000042A4bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00004234bc*sc*i*
alias: pci:v00008086d000002F0sv*sd000040A4bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00004034bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00004030bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00002034bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00002030bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00001552bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00001551bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00001030bc*sc*i*
alias: pci:v00008086d000002F0sv*sd000002A4bc*sc*i*
alias: pci:v00008086d000002F0sv*sd000002A0bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000264bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000260bc*sc*i*
alias: pci:v00008086d000002F0sv*sd0000023Cbc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000238bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000234bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000230bc*sc*i*
alias: pci:v00008086d000002F0sv*sd000000A4bc*sc*i*
alias: pci:v00008086d000002F0sv*sd000000A0bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000064bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000060bc*sc*i*
alias: pci:v00008086d000002F0sv*sd0000003Cbc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000038bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000034bc*sc*i*
alias: pci:v00008086d000002F0sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias: pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias: pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias: pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias: pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias: pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias: pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias: pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias: pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias: pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias: pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias: pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias: pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias: pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias: pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias: pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias: pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias: pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias: pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias: pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias: pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias: pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias: pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias: pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias: pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias: pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias: pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias: pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias: pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias: pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias: pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias: pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias: pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias: pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias: pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias: pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias: pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias: pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias: pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias: pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias: pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias: pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias: pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias: pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias: pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias: pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias: pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias: pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias: pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias: pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias: pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias: pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias: pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias: pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 5.4.0-51-generic SMP mod_unload
sig_id: PKCS#7
signer: Build time autogenerated kernel key
sig_key: 56:AA:1E:D4:49:F6:D7:44:76:6B:68:17:21:DC:0C:4D:B1:40:9F:BB
sig_hashalgo: sha512
signature: 6F:19:77:56:B8:55:EC:8A:82:D5:99:7F:84:26:E2:20:C2:F2:56:37:
32:5E:94:DB:0E:56:17:42:92:D3:F1:6B:DE:84:F5:17:58:50:DF:FF:
E6:85:6C:3F:24:16:B5:57:E5:72:3F:CC:89:E2:0B:0C:E1:E4:8D:F7:
7E:F2:8A:33:4E:6A:E9:4A:50:EA:1D:90:B5:D5:65:11:D2:F2:F6:50:
B1:0D:B0:B0:11:98:5E:79:12:F5:1F:BD:16:E7:09:6E:01:42:95:1A:
BA:9E:05:6D:7B:AB:61:39:07:A8:4E:D6:7C:93:23:7A:0D:81:88:E3:
E9:E8:30:EE:F5:CA:8F:06:2F:62:01:6B:05:85:02:48:6C:50:75:4E:
BA:26:7B:8C:25:9A:FA:A1:AA:B6:10:CB:06:71:EC:C2:61:37:F8:64:
B5:D8:8F:6C:48:72:9C:67:29:3B:26:F4:61:56:DC:68:D6:B3:0E:D6:
14:32:64:14:5C:AB:36:88:82:C9:33:13:F6:1B:06:4B:D5:5B:C6:29:
87:57:E5:56:89:E5:85:C9:93:A5:D2:0A:87:42:2B:F9:55:4C:D6:AE:
13:A8:94:10:E6:1F:E1:11:B5:0E:4E:36:44:54:01:5F:ED:EF:A1:B8:
C0:45:79:A2:CF:C5:96:E9:DB:53:8E:B2:09:8D:AA:9C:C0:86:45:52:
86:EA:BA:CF:E0:F0:4A:2F:70:5E:C7:E0:2E:0F:B9:E3:FC:39:DB:5E:
90:74:EE:04:3A:EC:82:BF:EC:3A:53:6C:DC:17:07:CB:EA:FA:B1:B2:
89:9C:BF:BC:BF:0D:1E:87:FB:F6:CD:92:53:8C:24:19:8B:81:34:55:
B8:9E:59:AE:A3:B1:9C:A3:2E:6B:FB:5D:AB:D8:03:FE:63:C3:AD:7D:
FB:A1:AA:51:F6:EE:D7:52:09:C3:AC:04:75:86:C0:5A:47:F8:E2:EC:
8A:0C:0B:DF:9C:1C:4D:D9:D0:94:9B:1D:4C:CE:73:16:6B:94:49:2D:
03:D5:4D:0F:0E:5A:FC:CF:7B:CA:12:3A:35:43:91:00:ED:D2:E6:08:
78:72:E0:98:7C:7B:46:6B:4B:F6:D6:DB:2F:83:26:79:B6:E8:E4:6E:
F9:5E:C5:59:65:01:B5:5F:97:5E:49:A7:EB:15:3E:FB:D2:96:58:49:
7F:9F:FA:6E:7D:B4:85:86:78:07:78:23:8C:2C:08:AB:36:17:9F:FD:
1F:BA:A9:9E:4E:7A:8D:AE:C7:F6:06:8C:8D:E3:47:C2:4C:EF:DE:C0:
78:C9:37:58:1C:B8:B6:18:9F:27:05:6F:6C:AF:18:67:A0:10:AE:BC:
E1:6E:40:F5:EB:00:0E:4D:CF:BA:0D:64
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: antenna_coupling:specify antenna coupling in dB (default: 0 dB) (int)
parm: nvm_file:NVM file name (charp)
parm: lar_disable:disable LAR functionality (default: N) (bool)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: 0 (bool)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: fw_monitor:firmware monitor - to debug FW (default: false - needs lots of memory) (bool)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
iwlwifi 331776 1 iwlmvm
cfg80211 704512 3 iwlmvm,iwlwifi,mac80211
[ 3.417979] iwlwifi 0000:3a:00.0: enabling device (0000 -> 0002)
[ 3.442427] iwlwifi 0000:3a:00.0: Direct firmware load for iwlwifi-cc-a0-50.ucode failed with error -2
[ 3.442528] iwlwifi 0000:3a:00.0: Direct firmware load for iwlwifi-cc-a0-49.ucode failed with error -2
[ 3.444162] iwlwifi 0000:3a:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 43.2.23.17
[ 3.444164] iwlwifi 0000:3a:00.0: Found debug destination: EXTERNAL_DRAM
[ 3.444166] iwlwifi 0000:3a:00.0: Found debug configuration: 0
[ 3.444368] iwlwifi 0000:3a:00.0: loaded firmware version 48.4fa0041f.0 op_mode iwlmvm
[ 3.516065] iwlwifi 0000:3a:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[ 3.530731] iwlwifi 0000:3a:00.0: Applying debug destination EXTERNAL_DRAM
[ 3.531083] iwlwifi 0000:3a:00.0: Allocated 0x00400000 bytes for firmware monitor.
[ 3.715628] iwlwifi 0000:3a:00.0: base HW address: dc:71:96:6a:92:3f
[ 3.732865] iwlwifi 0000:3a:00.0 wlp58s0: renamed from wlan0
Nope
AndrewG_Intel
Thank you very much for all the information provided.
Could you please type in this command: dmesg | grep “no suitable firmware found!”​ and share the output to check whether the suitable firmware is installed?
If the result is not empty, it means the system does not have a suitable FW. In that case, please visit here* https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi ​for supported FW, or here*​ ​https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/ for the latest versions.
If the issue persists after reviewing previous suggestions, please kindly provide the following details:
1- Type in this command: dmesg | grep ASSERT and provide the outcome.
If the output is empty, please follow this wiki: https://wireless.wiki.kernel.org/en/users/drivers/iwlwifi/debugging ​to extract dmesg and trace-cmd.
If the output has value, please collect from the wiki FW dump too.
2- Please provide an Intel® System Support Utility report for the Linux* Operating System:
https://downloadcenter.intel.com/download/26735/
Here is the Help Guide for the Intel® System Support Utility for steps on how to pull the report: https://www.intel.com/content/www/us/en/support/articles/000008563/software/software-applications.html
Andrew G.
AndrewG_Intel
We are checking this thread and we would like to know if you were able to review our previous post. Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
AndrewG_Intel
Hello @Realming_Grape
We are checking this thread and we would like to know if you need further assistance. If yes, were you able to gather the information previously requested? Please do not hesitate to contact us back if you have additional inquiries.
Andrew G.
Realming_Grape
Hi @AndrewG_Intel
Sorry for the delay. ive been away. for some reason, the wifi adapter started working, its a nice sight. There were a few Kernel updates but nothing i thought related to the adapter.
Thanks for all your help so far.:) Everything is working for me at the moment
AndrewG_Intel
Thank you for your response. Perhaps the Kernel updates had something to do with any improvement on the operating system side from which wireless functionality benefited. Anyway, we are glad to know that the wifi adapter started working!
If you have additional inquiries, please do not hesitate to contact us back.
Sincerely,
Andrew G.
AndrewG_Intel
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer being monitored. It has been a pleasure to assist you.
Sincerely,
Andrew G.
