16618 Discussions
VHDL code for Right Shift register
Hello All..
I have problem in my code. I have created code for 8 bit shift register right..
ie my input is 11001011
then in
1st clock :- output should be :- 01100101
2nd clock :- output should be :- 00110010
3rd clock :- output should be :- 00011001
4th clock :- output should be :- 00001100
5th clock :- output should be :- 00000110
6th clock :- output should be :- 00000001
7th clock :- output should be :- 00000000(Ie at the end of clock 8, it should be 0h)
Please correct my code :-
library ieee;
use ieee.std_logic_1164.all;
entity shift is
port(C, SI : in std_logic;
SO : out std_logic);
end shift;
architecture archi of shift is
signal tmp: std_logic_vector(7 downto 0);
begin
process (C)
begin
if (C'event and C='1') then
for i in 0 to 6 loop
tmp(i+1) = tmp(i);
end loop;
tmp(0) = SI;
end if;
end process;
SO = tmp(7);
end archi;
Thanks a lot
Your vector is std_logic_vector(7 downto 0) Left to Right, corrrect.
In your loop process, you are looping first with index value as 0.
So, tmp(0+1) = tmp (0); will result in tmp(1) getting written with tmp(0).
This will take the second from right location and load it with the right most location.
I do not believe this will accomplish your desired shift to the right, it will move the right most value into all the locations to the left.
You will then be loading the right most location with the SI value.
Just draw out step by step what you are trying to do and you will see that you might want to;
SO = tmp(0);
for i in 1 to 7 loop
tmp (i-1) = tmp(i);
end loop;
tmp(7) = SI;
and also, where is tmp declared as a register, not just as a signal?
Tmp needs to hold the value, right.
I hope this helps.
Hi..Avataar,
I am really really thankful to you..:)
shash_satish2002, its great that you are getting responses, but my advice is that if you keep using forums to help with homework and labs, you'll never do well during your exams or in your post-university career.
These questions can be answered by debug simulation and books...
Hello Sir,
I am sorry..But actually i am doing project in company and i am just beginner in this field but this forum help me lot.
Thank you sir.
Shah,
Where are you located, or, if you like, adjust your profile setting to allow mw to send you a private e-mail?
this is a 8 bit shift register with synchronous set siso
library ieee;
entity shift is
port(C, SI, S : in std_logic;
end shift;
begin
process (C, S)
begin
if (S='1') then
tmp <= (others => '1');
else
tmp <= tmp(6 downto 0) & SI;
end if;
end if;
end process;
SO <= tmp(7);
end archi;
i want to ask the meaning of the line that is in bold and red color i.e...
It's a synchronous preset of the SR to all '1'.
By the way, a signal name of tmp for the shift register is rather unimaginative, isn't it?
Hello all. I have this vhdl code for 4 bit shift register and i wonder why am i not getting any reasonable output after i simulate.
library ieee;
entity shift_reg is
port (
sin,en,clk : in std_logic;
q : out std_logic);
end shift_reg;
architecture shift_reg_beh of shift_reg is
signal shft_tmp : std_logic_vector(3 downto 0);
begin
PROCESS (clk,en)
BEGIN
IF rising_edge(clk) THEN
IF en = '1' THEN
q <= shft_tmp(0);
for i in 1 to 4 loop
shft_tmp(i-1) <= shft_tmp(i);
end loop;
shft_tmp(3) <= sin;
end if;
end if;
end process;
end shift_reg_beh;
My output q and the shft_tmp will always be in red and show no sign of being overwrited by the input. Plz help me out with this code .
thanks in advance...
have you connected sin to something in your simulation testbench?
is en set to '1'?
I think it has to do with 'uninitialised' registers. It looks like ModelSim RTL simulation has an issue with registers without a reset. I had a similar experience yesterday. In stead of adding a reset condition for every register, I just simulated at the Gate Level and got what I wanted ...
the Q output will only be uninitialised for 4 clock cycles of enable being high, assuming the input is set to '1' or '0'. You dont need an explicit reset.
i hv no testbench for it... i hv simply written that code...
in simulation. after add wave *
i force sin, clk and en to 1. in output my q as well as shft_tmp is all in red waves. i.e undefined.
when i set the shft_tmp to "1111" then i get shft_tmp as 1111 but the q is still the same in red. :(
you cannot force clk to 1. It needs to toggle, otherwise nothing internally will work.
well i hv tried toggling clock to by forcing 10ns of 0 value and then a 1. its the same result... do i need to toggle clock with the code like this:
wait for 1 ns; clk <= not clk;
sorry but i am just a newbie...
One question - how have you managed to simulate this code - there is an error because "i" goes out of range of the signal shft_tmp.
Now Ive fixed the error, here is the output from a testbench I whipped together - so there is no problem with code with the above error fixed:
OMG.... Tricky bro!!! it works... :) i have changed the loop from 1 to 3. I think that would be fine... i kept toggling the value of clock for every 10ns. I finally got the output :) THanks mate..
You earned me man... This is the first time ever any forum has helped me...
Guess what i am gonna be a permanent guy in this forum from now on.! THanks buddy!!!
Yes, the code in the loop is probably never executed, as the simulator would generate an error on shft_tmp(i) when i is 4.
Edit: and now I realize I should have clicked on 'page 2' before writing an answer :D problem was already solved
hi. for our class project, we are required to write the vhdl codings for a 5-bit left-to-right shift register. can anyone please guide us. thanks. or if anyone has the complete coding, that will be a great help.
