Hello All..
I have problem in my code. I have created code for 8 bit shift register right.. ie my input is 11001011 then in 1st clock :- output should be :- 01100101 2nd clock :- output should be :- 00110010 3rd clock :- output should be :- 00011001 4th clock :- output should be :- 00001100 5th clock :- output should be :- 00000110 6th clock :- output should be :- 00000001 7th clock :- output should be :- 00000000(Ie at the end of clock 8, it should be 0h) Please correct my code :- library ieee; use ieee.std_logic_1164.all; entity shift is port(C, SI : in std_logic; SO : out std_logic); end shift; architecture archi of shift is signal tmp: std_logic_vector(7 downto 0); begin process (C) begin if (C'event and C='1') then for i in 0 to 6 loop tmp(i+1) = tmp(i); end loop; tmp(0) = SI; end if; end process; SO = tmp(7); end archi; Thanks a lotLink Copied
Your vector is std_logic_vector(7 downto 0) Left to Right, corrrect.
In your loop process, you are looping first with index value as 0. So, tmp(0+1) = tmp (0); will result in tmp(1) getting written with tmp(0). This will take the second from right location and load it with the right most location. I do not believe this will accomplish your desired shift to the right, it will move the right most value into all the locations to the left. You will then be loading the right most location with the SI value. Just draw out step by step what you are trying to do and you will see that you might want to; SO = tmp(0); for i in 1 to 7 loop tmp (i-1) = tmp(i); end loop; tmp(7) = SI; and also, where is tmp declared as a register, not just as a signal? Tmp needs to hold the value, right. I hope this helps.- Mark as New
Hi..Avataar,
I am really really thankful to you..:)- Mark as New
shash_satish2002, its great that you are getting responses, but my advice is that if you keep using forums to help with homework and labs, you'll never do well during your exams or in your post-university career.
These questions can be answered by debug simulation and books...- Mark as New
Hello Sir,
I am sorry..But actually i am doing project in company and i am just beginner in this field but this forum help me lot. Thank you sir.- Mark as New
Shah,
Where are you located, or, if you like, adjust your profile setting to allow mw to send you a private e-mail?- Mark as New
this is a 8 bit shift register with synchronous set siso
library ieee; use ieee.std_logic_1164.all; entity shift is port(C, SI, S : in std_logic; SO : out std_logic); end shift; architecture archi of shift is signal tmp: std_logic_vector(7 downto 0); begin process (C, S) begin if (C'event and C='1') then if (S='1') then tmp <= (others => '1'); else tmp <= tmp(6 downto 0) & SI; end if; end if; end process; SO <= tmp(7); end archi; i want to ask the meaning of the line that is in bold and red color i.e... tmp <= (others => '1');- Mark as New
It's a synchronous preset of the SR to all '1'.
By the way, a signal name of tmp for the shift register is rather unimaginative, isn't it?- Mark as New
Hello all. I have this vhdl code for 4 bit shift register and i wonder why am i not getting any reasonable output after i simulate.
library ieee; use ieee.std_logic_1164.all; entity shift_reg is port ( sin,en,clk : in std_logic; q : out std_logic); end shift_reg; architecture shift_reg_beh of shift_reg is signal shft_tmp : std_logic_vector(3 downto 0); begin PROCESS (clk,en) BEGIN IF rising_edge(clk) THEN IF en = '1' THEN q <= shft_tmp(0); for i in 1 to 4 loop shft_tmp(i-1) <= shft_tmp(i); end loop; shft_tmp(3) <= sin; end if; end if; end process; end shift_reg_beh; My output q and the shft_tmp will always be in red and show no sign of being overwrited by the input. Plz help me out with this code . thanks in advance...- Mark as New
have you connected sin to something in your simulation testbench?
is en set to '1'?- Mark as New
I think it has to do with 'uninitialised' registers. It looks like ModelSim RTL simulation has an issue with registers without a reset. I had a similar experience yesterday. In stead of adding a reset condition for every register, I just simulated at the Gate Level and got what I wanted ...
the Q output will only be uninitialised for 4 clock cycles of enable being high, assuming the input is set to '1' or '0'. You dont need an explicit reset.
i hv no testbench for it... i hv simply written that code...
in simulation. after add wave *
i force sin, clk and en to 1. in output my q as well as shft_tmp is all in red waves. i.e undefined.- Mark as New
when i set the shft_tmp to "1111" then i get shft_tmp as 1111 but the q is still the same in red. :(
you cannot force clk to 1. It needs to toggle, otherwise nothing internally will work.
well i hv tried toggling clock to by forcing 10ns of 0 value and then a 1. its the same result... do i need to toggle clock with the code like this:
wait for 1 ns; clk <= not clk;
sorry but i am just a newbie...
OMG.... Tricky bro!!! it works... :) i have changed the loop from 1 to 3. I think that would be fine... i kept toggling the value of clock for every 10ns. I finally got the output :) THanks mate..
You earned me man... This is the first time ever any forum has helped me... Guess what i am gonna be a permanent guy in this forum from now on.! THanks buddy!!!- Mark as New
Yes, the code in the loop is probably never executed, as the simulator would generate an error on shft_tmp(i) when i is 4.
Edit: and now I realize I should have clicked on 'page 2' before writing an answer :D problem was already solved- Mark as New
hi. for our class project, we are required to write the vhdl codings for a 5-bit left-to-right shift register. can anyone please guide us. thanks. or if anyone has the complete coding, that will be a great help.
