simulation error
im a newbie in quartus II.i tried to simulate the full adder in verilog hdl but it seems cant work!!when i tried to compile the files, there's no error but have a few warnings.
but when it comes for simulation...the msg appeared>>
Error: Can't launch the Active-HDL software -- the path to the location of the executables for the Active-HDL software were not specified or the executables were not found at specified path.
Error: You can specify the path in the EDA Tool Options page of the Options dialog box or using the Tcl command set_user_option.
Error: NativeLink Simulation failed
Am i did the wrong files source code or the way i setting the eda simulation tools is not correct??pls help me...
this is my full adder file
module fulladder (a,b,carry_in,sum,carry_out);
input a,b;
input carry_in;
output [1:0] sum;
output carry_out;
half_adder H1 (carry, sum[0], a, b);
half_adder H2 (carry_out, sum[1], carry, carry_in);
endmodule
module half_adder(carry, sum, a, b);
input a;
input b;
output carry;
output sum;
xor X1 (sum, a, b);
and A1 (carry, a, b);
endmodule
Go to tools -> options. Under General, EDA Tool Options. Set the executable path for Active-HDL simulator (e.g. C:\Program Files\Aldec\Active-HDL 7.2\BIN). Then later you can launch the simulator using native-link (i.e. Tools->EDA Simulation Tools -> Run ...)
u mean set the executable path for the same file?i tried to do like what u said but it doesnt work
