FPGA Intellectual Property
6360 Discussions
DDR2 RAM on DB4CGX15
I have a problem with the DB4CGX15 Borad and the implemented DDR2. In SOPC Builder I choosed the DDR2 SDRAM High Performance Controller. When I completed the SOPC System, gerneration was succesfull. When I go back in Quartus and compile I get an error massage:
Error: The design contains 2 blocks of type "Embedded multiplier block" but the selected device EP4CGX15BF14C6 does not support such blocks
From the datasheet I also know the EP4CGX15 has no embedded multipliers. So where can I pull them off? Or have I made another error?
Thanks in advance!
Hi again,
finaly I found it by myself. The failure was done by myself too. I forgot to turn of the Hardware multiplier implementation in the nios2. So the error wasn´t a result of the DDR2 RAM Controller.
