oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
Python Installation fails 2022.1
MWind2
New Contributor III
I get from offline install or modify
and a
12/22/2021 14:53:54:301 : 36552 : ERROR : Installation of component has failed.
Component id: intel.oneapi.win.python3, name: Intel® Distribution for Python*, version: 2022.0.0-118.
Error: Sequence execution failed.
when trying to install or modify on a computer with lots of versions of VS(2022,2019,2017,2015, 2010,2008,2005) and 1api 2021.4 ,  2019.6,2017.8).
Presently trying on cleaner VS 2022,2019 and 2021.4  system and it works.
Failure seems to happen sometime in second cmd window as the failure one is shorter in duration than the successful one.
ArpanB_Intel
Internal update:
The user has communicated that he has installed multiple versions of Microsoft Visual Studio and Intel® compilers on a different drive without any incident and is satisfied with the outcome. Thus, closing this thread.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
Rizwan1
I am getting the same issue on CentOS 8 with installation of intel python
Vasily_R_Intel1
Hi Rizwan1,
Could you pls share logs with us? On Centos they are in /tmp/username/intel_oneapi_installer/
It will really helps us!
Thank you.
Rizwan1
Dear,
Please find the logs attached
Vasily_R_Intel1
Thank you! Issue is addressed to product team.
ChrisB_Intel
For anyone still experiencing the issue.
We are still investigating this issue, however, as a test would you mind downloading the offline installer, if you don't already have it, and rename that .exe file to a .zip file. Then extract all the contents and run it from the extracted folder. Please let me know the outcome.
Chris
MWind2
New Contributor III
Do you mean rename w_BaseKit_p_2022.1.0.116_offline.exe w_BaseKit_p_2022.1.0.116_offline.zip?
ChrisB_Intel
Yes, correct. Then extract the files into a directory and run the install from that directory.
Chris
MWind2
New Contributor III
01/11/2022 12:18:47:896 : 15208 : ERROR : Installation of component has failed.
01/11/2022 12:18:47:897 : 15208 : MESSAGE : Operation 'intel.oneapi.win.python3,v=2022.0.0-118' execution is finished with status Fail.
Rizwan1
I am also getting similar message in CentOS 8
ChrisB_Intel
Apologies for the issues, we have a bug open with engineering and are waiting for a response. I will update you as soon as I have additional information.
Chris
ChrisB_Intel
Mwind2,
I just sent you a private message, please take a look.
Chris
MWind2
New Contributor III
I'm trying to find it in my dashboard inbox and seeing zero messages though I received email with no link to reply.
(Browser was blocking pop-ups that showed messages)
ChrisB_Intel
If you look across the top, and click what I have highlighted, do you show no messages?
Rizwan1
ArpanB_Intel
Internal update:
