oneAPI Registration, Download, Licensing and Installation
Support for Getting Started questions related to download, Installation and licensing for Intel oneAPI Toolkits and software development tools.
1324 Discussions
Re: Re:Bootstrapper.exe - Bad Image - Qt6Core.dll
dajum
THis seems to be a generic problem.  Can we get a solution everyone can read about here? I need to know how to fix this as well.
ArpanB_Intel
Hi David, thank you for reaching out to us. We are working on the issue. We will soon share the solution with you.
ArpanB_Intel
David, we have contacted you internally with some information. Please check your inbox for further updates.
ArpanB_Intel
David, you would have to fix the corrupted files.
Use Command Prompt commands to repair system file corruption:
  • Open Command Prompt as administrator
  • Use the following command and press Enter: sfc /scannow
  • Reboot your system
  • If SFC returned an error, then use the following command lines, pressing Enter after each:
  1. DISM /Online /Cleanup-Image /CheckHealth
  2. DISM /Online /Cleanup-Image /ScanHealth
  3. DISM /Online /Cleanup-Image /RestoreHealth
We would like to know.
ArpanB_Intel
David, unfortunately we were unable to hear back from you.
If you have any further queries, please post a new question as this thread will no longer be monitored by Intel®.
