12606 Discussions
CRC and static data location
Hello all nios users,
I have 2 questions that are somehow related:
1. Is there a built in feature in the IDE or compiler that enables to calculate a CRC of any kind on the build code? If so, where is it being placed?
2. More general question: can I "force" location of static data in pre-determined memory section (something like pragma locate in other compilers)? how?
Thanks a lot for your help,
A.G.
Hi A.G.
I don't know of any CRC feature but it may be worth checking the GCC documentation.
It is possible to specify a memory section to place code or data in e.g.
alt_u32 cheese __attribute__ (( section (".nv_sram")));
would put the variable 'cheese' into the memory device called 'nv_sram' in your system.
To verify where the linker has placed this variable (and everything else besides), add the following compiler option to your Project properties:
-Wl,-Map,Output.map
This will create a linker map file called 'Output.map' in your project's output folder.
I hope this is useful.
All the best
Sharkybaba
